Previous in Forum: What will hold up to the heat?   Next in Forum: GIT (Gas injection Technology)
16 comments
tolerances
10/01/2007 6:57 PM
Which is more important, form specifications or size specifications? Why?
Pathfinder Tags: hello
Re: tolerances
10/02/2007 4:18 AM
When you order a meal which is more important , flavour or quantity?
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
Re: tolerances
10/03/2007 10:56 PM
or put another way, when you need a slicker (rain-coat?) would you prefer efficient or effective? - hee
Engineering Fields - Manufacturing Engineering - New Member United States - US - Statue of Liberty - New Member
Re: tolerances
11/03/2007 11:26 PM
I love these easy ones: flavour
Vote your hope not your fear.
Good Answers: 97
Re: tolerances
10/02/2007 5:18 AM
Size, shape and tolerance are all important.
It is almost impossible too manufacture components with precise measurements. The tolerance is set to specify the maximum deviation allowed before the component becomes unusable for the original purpose.
When the tolerance is exceeded the part must be considered a different size.
Re: tolerances
10/02/2007 7:39 AM
Thanks for you answers, I do have another.
  1. When precision surfaces are required on a casting, which one of the several types of castings is most likely to need a machining operation subsequent to casting? Which two types are least likely to need subsequent machining?
Engineering Fields - Mechanical Engineering - By Degree Engineering Fields - Manufacturing Engineering - By Profession Popular Science - Weaponology - By Interest United States - Member - Member Since My Inception
Re: tolerances
10/03/2007 7:47 AM
That all depends on the complexity of the part and its function.
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Re: tolerances
10/20/2007 9:50 PM
Why do you insist on others doing for you what you should be doing for yourself.
You are cheating yourself by sloughing off your HOMEWORK for others to do.
Get smart, and get to WORK on YOUR WORK.
Re: tolerances
10/21/2007 10:44 AM
Damnit S Stan! Have I been out of school that long? I completely missed it. But not you; you 'ol hound dog! You sniffed the bugger right out!
I would like to resend my previous reply and in it's place, substitute Stan's.
cr3
Re: tolerances
10/24/2007 6:26 AM
I concur S Stan's got a great nose!
Way to tell him...
Re: tolerances
10/02/2007 7:41 AM
Re: tolerances
10/02/2007 10:31 AM
Form, Fit and Fuction... All equally important.
Re: tolerances
10/05/2007 3:15 PM
There is your answer i a nutshell. When one aspect is deemed more important than another GD&T symbology and notes will indicate so by us of such as MMC, circularity, flatness and the likes.
I am looking right now at ASME Y14.5M-1994 in it's entirety and it is well over 1000 pages. All adressing this matter.
cr3
Re: tolerances
10/02/2007 10:53 AM
Size is very important. Especially if you want wallpaper to stay on the wall.
Re: tolerances
10/02/2007 11:43 AM
I would have thought that the paste was more important!
Re: tolerances
10/03/2007 10:53 PM
self pasting isn't - better to use paste on self pasted and book it -
. . . learned from a true, one armed paper hanger -
Re: tolerances
11/03/2007 11:50 PM
The straightness tolerance can be applied to either a cylindrical or flat features. For a cylindrical feature, there are two possible intentions. When applied to the cylinder's surface, the symbol's intent is to control the straightness of each individual line element making up that surface. When attached to the diameter dimension line and the diameter symbol is contained within the feature control frame, the cylinder's centerline is being controlled within a cylindrical tolerance band of a specific size. When the straightness symbol is attached to an otherwise flat surface, the line elements lying on he surface of the part and running parallel to the straightness symbol are being controlled.
Register to Reply 16 comments
All About M.E. (2); Anonymous Poster (3); eagertask (2); Hendrik (1); Labyguy (1); Mr. Truman Brain (1); Stirling Stan (1); TexasCharley (2); tubenut (2); user-deleted-1105 (1)
