Previous in Forum: Oil Ring Lubrication   Next in Forum: Relative Centrifugal Force and RPM
Gaskets Used in Sulfuric Acid Manufacturing Industries
12/10/2018 3:39 AM
Preferred Gaskets for the following services 1. SO2 (High Operating temperature -400 °C) 2. SO2 (Low Operating temperature -80 °C) 3. Liquid Sulfur (100-135 °C temperature) 4. Sulphuric Acid (75-100 °C) 5. High Pressure Steam (Superheated 37 Barg & 370-380 °C)
Good Answers: 181
Re: Gaskets used in sulfuric acid manufacturing industries
12/10/2018 4:07 AM
Do you want to post the rest of your homework paper?
12/10/2018 5:18 AM
The preference can be determined by using the piping standards documentation applicable to the facility where the installation is, or is due to take place.
The compatibility between the fluids and the gasket materials can be ascertained by using any number of corrosion compatibility charts, of which here is one (not an endorsement - other corrosion compatibility databases are available).
Re: Gaskets Used in Sulfuric Acid Manufacturing Industries
12/10/2018 7:01 PM
There is no such thing as -400ºC.
01/16/2019 10:50 AM
swetha ....
There is no sense in using niceties such as "please" "thank you" or "could you help me".
Always just make rude demands of others and expect that they will be eternally grateful for the opportunity to meet your demands ...
Your welcome .....
01/17/2019 9:36 AM
Anonymous Poster (1); Carl_E (1); PWSlack (1); TonyS (1); Tornado (1)
