Previous in Forum: Corn Stove Ducted to an Oil Furnace?   Next in Forum: Surge Ring in HT Motors
8 comments
DC Variable Speed Motor Controller
10/03/2007 9:02 PM
I am trying to find an economical motor controller for 12 V DC hobby motors. I need the motors to go in forward and reverse and variable speeds (very slow to full speed). I'm currently using the Bardac 200 XLV (http://www.bardac.com/pages/products/servo.html), but at $300 a piece they are little spendy, for the current project, I have spent a couple of days looking, but I cannot find anything like these controllers. I was just wondering if any of you would have any ideas.
Thank you in advance,
Jim
Re: DC Variable Speed Motor Controller
10/04/2007 3:48 AM
A variable speed feedback controller, perhaps? They can be had off the shelf for less than £25GBP.
http://www.stocktonmodeller.co.uk/products_model_trains_gaugemaster_controllers_handheld_controllers_hh_details-3936.html
(Other makes and suppliers are avaliable).
The favourite ones here are the ECM Compspeed type CA, the one with a reversing switch. They can be used with the smallest of low-inertia motors provided a ballast resistance of 75-150Ω is placed in parallel with the motor. The hand-built model railway locomotive achieves this typically by placing a grain-of-wheat bulb in the firebox so that, at speed, the firehole door hole glows red-yellow. The CA is not available new, though many previously-enjoyed ones can be found and are readily sought after. eBay, perhaps?
10/04/2007 11:14 AM
Thanks, but I was hoping to find something that would go "in-line" and I can control with a joystick. Any ideas?
Good Answers: 19
10/04/2007 11:49 AM
Good Answers: 18
10/05/2007 8:47 AM
You don't mention the power of the motor. What is it?
There is a single IC solution to this problem for up to 5 amps. Apex makes one.
10/05/2007 11:46 AM
Specifications are as follows:
Voltage -- 12 V DC
RPM -- 35
Idle Current Draw -- .2 Amps
Loaded Current Draw -- 1.1 Amps
Let me know if you need anything else.
Good Answers: 18
10/05/2007 1:30 PM
Did you check out the Apex site?
10/06/2007 11:01 AM
Do you like to do something using your "ingenuity?
Use Op-amplifier with output Power transistors.
I did a few and was very happy having hands-on electronics. Your motors are exactly well suited for this project.
India - Member - moorthi
10/06/2007 5:19 AM
it is very simple circuit. you can design it yourself using ordinary transistor.if you want further ideas feel free to contact me at meignana_moorthi@yahoo.co.in.
Register to Reply 8 comments
Anonymous Poster (1); Bill (2); FlyingAce (2); moorthi (1); PWSlack (1); Ried (1)
