Previous in Forum: Who Knew this Bloke had a Doctorate in Astrophysics?   Next in Forum: Rock From the Moon
9 comments
Can Batteries Be Taken on Board?
01/08/2019 4:23 AM
Can batteries be taken on board? Do I need to register the battery before taking it to the plane?
Pathfinder Tags: battery
Re: Can Batteries Be Taken on Board?
01/08/2019 8:17 AM
Button cells in a key fob or 10,000 pounds of lithium ion?
01/08/2019 8:55 AM
The question is best answered by contacting the transport provider directly.
01/08/2019 11:39 AM
Here in the United States, lithium ion batteries with less than 100 watt-hours may be taken in carry-on luggage. There are several categories of batteries/cells and more details are on the TSA website. The specifics are detailed in this link:
https://www.tsa.gov/travel/security-screening/whatcanibring/all
Put batteries into the search tool on this page to filter your results.
01/08/2019 1:07 PM
These restrictions can change at any time, so you need to get instructions from the airline you will be flying on....the rules vary from plane to plane, country to country and for international and domestic flights...
..."Aug 2, 2018 - The FAA forbids passengers from checking spare (uninstalled) lithium metal batteries, requiring them to be carried on. In addition, the FAA says that “all spare lithium batteries must be removed from the bag and kept with the passenger in the aircraft cabin,” when a carry-on bag is gate checked."...
https://thepointsguy.com/news/overheated-lithium-could-bring-down-plane/
01/08/2019 3:54 PM
01/09/2019 8:05 AM
If they're attached to a box with a button on it, NO!
01/10/2019 9:07 PM
Look on the airlines website... they’ll list it there.
01/29/2019 4:12 AM
Thank you for your answer. I'll ask.
01/19/2019 3:28 AM
As both an Aero Engineer and a Pro Pilot , generally the answer has to be " No". Batteries can become electrolytically unstable too easily , especially when not stationary.
Normal Battery Operation is always switched , and heavy continuous vibration plays havoc with switches.
When a Battery Cell Short Circuits , lots of heat is produced. If it's un noticed , like in a Cargo Bay onboard an Aircraft , this can easily cause a Cargo Fire.
Generally , as a Rule , when Loading Aircraft Cargo , Batteries are separated from what device it is they power . This illiminates the short circuit / overheat problem at the source .
Many Cargo Loads of Laptop Computers have Spontaniously Ignited due to Lithium Batteries Overheating and self destructing in a Cargo Bay .
They have even blown holes in Airframes as they come apart , Lear Jets were prone to this , the early ones .
Battery Doors just exploding and leaving a huge hole , with no more Battery where there was one at Take Off .
Aircraft Rated Liquid Cells are Gell now , and highly Explosion Proof . ( GILL / CONCORDE ).
Conventional Automotive Type Wet Cells are still out there , and still very popular , but they have physical chemical limitations.
One is : They produce Hydrogen Gas , and Oxygen Gas , when they charge , and to a lesser degree , when they discharge as well'.
The Main Fuel in the NASA CHALLENGER ONE Disaster was these two Volatile Gasses
Hydrogen mixed with Oxygen . Explosively Volatile when mixed .
Steele113
Bazzer Englander (1); Brave Sir Robin (1); Burton (1); Dragon113 (1); JE in Chicago (1); phoenix911 (1); PWSlack (2); SolarEagle (1)
