Previous in Forum: Fluid Flow Question   Next in Forum: A Wave in Time/Tune
RS1200
01/17/2019 3:06 PM
HAVE A RS1200 ONAN
RUNS 10 SECONDS SHUT DOWN, MONITOR GOVERNOR CONTROL WORKS FINE .
OIL PRESSURE SENSOR WORKS FINE
ALL CONNECTIONS ARE TIGHT
LOOKS AS IF PCB HAS A ISSUE
Re: RS1200
01/17/2019 3:42 PM
Maybe a blocked fuel line.
Good Answers: 203
Re: RS1200
01/20/2019 11:38 AM
How long between starting attempts? If the fuel line has a fuel filter in it a difference in the time, shorter-->less clogged, would suggest a potentially partially or almost completely clogged fuel filter. If the effect between the two times is equal that would suggest that it is something besides the fuel filter.
This comparison would be greater with gravity fed lines compared to fuel pump fed.
Good Luck, Old Salt
Re: RS1200
01/24/2019 9:48 AM
So, in the absence of certainty, it is maybe something else instead.
Re: RS1200
01/17/2019 5:09 PM
Re: RS1200
01/17/2019 5:47 PM
Re: RS1200
01/18/2019 2:24 PM
What type of fuel? If NG or LP, could be supply or demand regulator. Need to check fuel pressure while starting/running...
Re: RS1200
01/22/2019 10:45 AM
It sounds like a service visit by the manufacturer’s service team is overdue.
Register to Reply 7 comments
genmaster (1); lyn (1); old salt (1); PWSlack (2); Rixter (1); SolarEagle (1)
