Previous in Forum: Crude Oil   Next in Forum: Crosslinked Polymers: Safety?
Glue for Glass
10/05/2007 11:34 AM
Hello
Does any body know a glue that would bond the glass, but optically the joint would not be visible.
Thanks
Re: Glue for Glass
10/05/2007 1:58 PM
You can buy car windscreen repair kits that will repair small windscreen chips using UV setting optically clear adhesive of some kind...
Many windscreen repair companies use this stuff, a quick telephone call will tell you what it is...
John.
Good Answers: 58
Re: Glue for Glass
10/06/2007 8:15 AM
Historically, people have used water white rosin to cement lenses together to make achromats. I use a clear silicone adhesive + a primer to cement lenses to diving masks for underwater optics, there may be epoxies that are clear enough for this application, and lastly, there is crazy glue. Depends on the strength you need and the environmental conditions. Another tip; many chemists are offended by the term "glue". They are more comfortable when you use the term, "adhesive".
United States - Member - New Member Engineering Fields - Optical Engineering - New Member Popular Science - Cosmology - Astrometrist Engineering Fields - Engineering Physics - New Member
Re: Glue for Glass
10/06/2007 2:55 PM
You may be able to find something in a local hobby store. But if you want a professional grade adhesive, there are many suppliers of optical cement. Some are UV curable, some are 2 part epoxy. The choice depends upon your requirements. Do you need strength? Is the glass to be used over a wide temperature range? etc.
Search the web or Google for "optical Cement". Or search cr4.globalspec .
Two companies which you might try are Master Bond or Summers. Look for adhesives which bond lenses, prisms, or optical fibers.
Call the suppliers and discuss your specific needs with them and let a technical representative suggest an appropriate adhesive for your use.
Good Answers: 94
Re: Glue for Glass
10/08/2007 6:08 AM
2 part acrylic adhesive works well & is transparent. Application is by having an activator on one surface & the adhesive on the other, sets in a few minutes.
I'm not sure if it would tend to go yellow with age?
Electroman (1); GWJ (1); Nigh (1); welderman (1)
