Previous in Forum: Rock From the Moon   Next in Forum: Aviation Industry Hardware/Software
28 comments
Aircraft
01/31/2019 2:01 AM
What are these diamond shaped opening on the bottom of the F 22 aircraft?
5
Re: Aircraft
01/31/2019 7:21 AM
Why do you need to know?
Reply Good Answer (Score 5)
Good Answers: 75
Re: Aircraft
02/01/2019 12:37 AM
Interesting. I wouldn't have thought, till now, that a GOOD QUESTION could also be a (or at least contain it's own) Good Answer.
And a GA from me, too!!
Re: Aircraft
02/01/2019 6:14 PM
Re: Aircraft
01/31/2019 10:07 AM
Looks like squares and rectangles to me.
Re: Aircraft
01/31/2019 10:49 AM
All your going to get are guesses... my guess is, some type of pressure equalizer for the Pratt & Whitney F119-PW-100 turbo fan jet engines... what ever that may mean...
Re: Aircraft
01/31/2019 1:32 PM
Re: Aircraft
01/31/2019 2:29 PM
air intakes for the engines
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Re: Aircraft
01/31/2019 3:44 PM
I think it’s a whistle....
Re: Aircraft
01/31/2019 5:46 PM
Re: Aircraft
02/01/2019 8:25 AM
its those Deer Whistles but this time for other airplanes....
Good Answers: 75
Re: Aircraft
02/01/2019 8:28 AM
Airplane whistles? That would explain the strange noises those things sometimes make. But I thought the strange noises came from the stealth models.
Re: Aircraft
02/01/2019 11:08 AM
No they’ve found that those stealth models were so quiet, the ground crews didn’t know they were taxiing up behind them, and to avoid getting run over an engineering change notice was issued to medicate mitigate the problem...
The fix, they added these to the turbofans... problem solved.
Re: Aircraft
01/31/2019 11:29 PM
Blue and gray water dump tank nozzles.
Re: Aircraft
02/01/2019 8:11 AM
This is an air-force aircraft...
Re: Aircraft
02/01/2019 11:58 AM
Here is an exploded diagram of the underside of the an F-22. I cannot find the key for this image. (Click image for source)
HUSH
Re: Aircraft
02/04/2019 9:56 AM
The drawing may not have a key, but at least we know the holes belong there!
Re: Aircraft
02/04/2019 3:17 PM
Black holes?
Re: Aircraft
02/01/2019 12:55 PM
Go to a toy store, buy & build the model and you will probably get your answer.
Re: Aircraft
02/01/2019 1:53 PM
Ask the Chinese military they should know since they pilfered the design data.
Re: Aircraft
02/02/2019 11:20 AM
Targets.
Re: Aircraft
02/02/2019 11:38 AM
If I tell you ...
CARPE CRUSTULORUM!
Re: Aircraft
02/04/2019 5:36 AM
But remember,you can't have your CRUSTULORUM and eat it too.
Re: Aircraft
05/21/2020 9:06 AM
Finally someone who understands!
CARPE CRUSTULORUM!
Re: Aircraft
02/03/2019 4:06 PM
They look like part of the undercarriage doors to me
Re: Aircraft
02/04/2019 5:32 AM
That is where they put the hand crank levers.Newer models are updated for electric start.
Good Answers: 53
Re: Aircraft
02/05/2019 11:29 AM
Are you sure you know everything else that looks at the right of those diamond shaped holes?
Re: Aircraft
05/17/2020 10:09 AM
Originally thought it was chassis wings. Then there was soap about the hanging points of the weapon. Didn't study this plane, it's hard to be specific. The extreme thought was soap about the fuel filter access doors.
Re: Aircraft
05/17/2020 10:42 AM
They may be ports to equalize the air pressure inside of the bomb bays to prevent explosive decompression when opened,or to provide assistance with positive pressure to assist opening the bomb bay doors against the high velocity outside air.This would reduce the size and weight of the required hydraulics.
Reply to Forum Thread 28 comments
AaronWilliams (1); Don Blashka (1); HiTekRedNek (3); HUSH (1); JE in Chicago (1); jhowdy (1); johnhotmer (1); micahd02 (2); Mike W (2); not so smart (2); phoenix911 (3); PWSlack (1); rakesh_semwal (1); SolarEagle (1); Ti QE (1); tonyhemet (1); Usbport (2); WAWAUS (1); wmerryall (2)
