Previous in Forum: Generator and Capacitors   Next in Forum: Solid State Regulator for Lucas Generator
FVR Question
03/02/2019 2:22 PM
dear sir
we have EX2100 excitation control, the setting of FVR =3.65=400 please can any
one help me to explain what mean by these numbers
thanks
Pathfinder Tags: AVR
Re: avr
03/02/2019 3:41 PM
Re: avr
03/02/2019 3:43 PM
Probably in here...
http://www.manualsdir.com/manuals/106726/ge-ex2100.html
..."Maybe this explains it:
pdfstream.manualsonline.com/7/7079df42-4464-427b-b181-4496e6281f13.pdf
page 2-21:
"Field Voltage and Current Regulators - FVR & FCR The Field Voltage Regulator (FVR) is the typical manual regulator supplied on most applications and uses the generator field voltage as the feedback input. While FVR does permit the current to vary as a function of the field resistance, the FVR makes the manual regulator completely independent from the over excitation limiter. FVR uses the voltage from the generator field as feedback, with a setpoint from the MANUAL REF block. A PI regulator with integral windup protection generates the output. During operation in AVR mode, the output of the AVR is passed directly to the FVR output with no signal conditioning. On units that operate with an inner field voltage regulator loop such as compound exciters and some high ceiling exciters, the FVR uses a setpoint from either the AVR or the MANUAL REF block, and is always operational whether in manual or automatic operation.
The Field Current Regulator (FCR) is a special application of the manual regulator and uses the generator field current as the feedback input. The current setpoint is generally switched between a high level and lower level to provide transient forcing capability as well as steady state operation within the capability of the generator. Generally the setpoint is larger than expected field currents and the integral preset is operational. The FCR output is held at positive ceiling until enable becomes true which allows the output to follow the P+I regulator. The bridge firing command is the smaller of the FVR and FCR outputs. While it does regulate constant field current over varying field temperature, FCR is not the standard manual regulator.""...
https://cr4.globalspec.com/thread/110323/Field-Regulator
Additionally....
https://ctc.control.com/thread/1348990642
Good Answers: 22
Re: avr
03/03/2019 6:57 AM
If voltage input to AVR is 110V, 3.65 corresponds to 400V (3.65x110 = 400V).
I am just guessing.
Raghunath
Re: FVR Question
03/04/2019 1:10 PM
The OEM certainly can. In the absence of the Operation and Maintenance Manual for it, a to the OEM's Technical Helpline is all that is needed.
Oh, and https://www.acronymfinder.com/FVR.html can explain the rest.
Please define TLAs before using them.
Register to Reply 4 comments
lyn (1); PWSlack (1); raghun (1); SolarEagle (1)
