Previous in Forum: Mitsubishi VFD Dilemma   Next in Forum: 6.6 kV Switchgear
3-Phase Motor
10/08/2007 7:20 AM
How can I connect a 3-phase motor to run on 220v, single phase?
Re: 3 phase motor
10/08/2007 8:30 AM
Via an inverter that generates a three-phase supply from a 220V single phase supply.
United States - Member - BoatMan
Re: 3-Phase Motor
10/08/2007 9:13 AM
It might be easier to just change the motor. As well as cost less.
"Only one life, will soon be past, only what's done for Christ will last." Dale Linson
Re: 3-Phase Motor
10/08/2007 11:13 PM
Most practical.
Good Answers: 52
Re: 3-Phase Motor
10/08/2007 10:12 AM
You need some sort of Phase converter as mentioned. It may be possible to do this with another smaller 3 phase motor, but a proper 3 phase converter is definitely the best way. Here are some links on the topic that may help you.
Re: 3-Phase Motor
10/08/2007 2:54 PM
Single phase to 3-phase inverters (or variable speed drives) really are not that expensive now days and are readily available. How big is the motor?
Re: 3-Phase Motor
10/09/2007 10:23 AM
If you want to play with 3-phase motor you can do this . If this motor has star connection ,380 V you should shange connection in D and connect motor on 220 V with capacitor between free and one of used terminal .If you are serious you have to provide 3 phase converter . Good luck !!
Escape Pod (1); frankd20 (1); jack of all trades (1); MUKULMAHANT (1); Panta SD (1); PWSlack (1)
