Previous in Forum: Integrating Building Management System with SCADA   Next in Forum: Infrared Flammable Gas Detection Case Studies
14 comments
Coriolis-Type Flow Meter Issue
04/12/2019 12:51 AM
We are having two type liquid sulfur loading pumps (Centrifugal and gear pump) .It has been observed that when centrifugal pump used to transfer liquid sulphur mass flow meter works fine but in case of gear pump it goes to IOP and shows drive override .Please suggest,
Re: Coriolis type flow meter issue
04/12/2019 1:35 AM
I suggest you don't use the gear pump....Is this molten sulfur? Is the gear pump internal or external? Are these pumps using the same lines? Is the gear pump installed above or below the process piping? Horizontal or vertical mounted? What pressures are you operating at? What differences are there between the pumps other than type of pump? Is there any air or gases in the lines? Is the gear pump recently new or maintained?
https://control.com/thread/972958635
https://www.global.weir/newsroom/news-articles/navigating-the-business-of-dirty-sulphur-pumps-important-considerations/
https://www.michael-smith-engineers.co.uk/resources/useful-info/gear-pumps
04/12/2019 3:21 AM
Re: Coriolis-Type Flow Meter Issue
04/12/2019 1:05 PM
You DID call the manufacturer of the Coriolis-Type Flow Meter didn't you?
If not, do it now!
They, and only they, are qualified to answer your question.
All this is a waste of time.
Make that call, now!
04/12/2019 3:23 PM
It could be the gear pump is generating vibrations that affect the Coriolis flow meter.
https://www.bronkhorst.com/blog/how-to-deal-with-vibrations-using-coriolis-mass-flow-meters/
04/15/2019 7:42 AM
...and it might not. Without the Original Poster coming back to the forum with a definitive answer from the flowmeter manufacturer, the forum is not in a position to know.
04/15/2019 11:14 AM
[Comment withdrawn at edit.]
04/12/2019 4:28 PM
It might be that the controller is not set for the higher pressure that the gear pump may be producing....check the parameters...
04/15/2019 7:43 AM
...and it might not. Without the Original Poster coming back to the forum with a definitive statement on the flowmeter, the forum is not in a position to know.
04/12/2019 5:23 PM
It's picking up Good Vibrations from the gear pump, causing it to OIP/IOP/IPO, whatever.
04/15/2019 7:44 AM
One hopes it isn't pumping TLAs...
04/12/2019 11:16 PM
If you can find a manufacturer of suitable flexible expansion or vibration isolators for that temperature and pressure, it might help to reduce the vibration transmitted.
The manufacturer installation instructions are typically quite specific on piping construction and methods, there could be some good suggestions there.
I'm impressed you found a supplier for molten sulfur coriolis meter. It may be that a different pitch or speed of the gear pump might get you off what appears to be a critical frequency of the flow tube loop excitation.
04/15/2019 10:20 AM
Without such basic information as flowrates, temperatures and pressures, any WAG will do...
04/15/2019 11:16 AM
There are solutions that can be applied. It depends upon the individual flowmeter and the circumstances of its installation, so contact the manufacturer for advice over the telephone.
Good Answers: 54
06/25/2019 4:34 AM
Just a guess (or WAG as PWSlack likes to call it):
Since coriolis flowmeters vibrate the flowtube, using a pulsating flow (via the gear pump) probably affects its performance. Putting in a pulse dampener might solve the problem.
regards,
Vulcan
Register to Reply 14 comments
Anonymous Poster (1); lyn (2); PWSlack (6); Rixter (1); rwilliams (1); SolarEagle (2); Vulcan (1)
