Previous in Forum: D.O. and H.G. Fuses: Advantages?   Next in Forum: Turbo Core Compressor
17 comments
AC coil
10/11/2007 7:16 AM
Can you use an 24VAC coil with 24VDC? The coil is in a mercury contactor.
Re: AC coil
10/11/2007 7:27 AM
Yes - until either the upstream fuse blows or the coil overheats. The AC coil will be wound in a coarser wire than the DC and will pass a lot more current than the DC one when it is connected to a DC source.
Far better to replace the AC coil with a DC one before energising it.
Re: AC coil
10/11/2007 7:48 AM
Also the core material and the way its made is different for an ac energised coil compared to a dc coil...
#John.
Good Answers: 50
Re: AC coil
10/12/2007 12:28 AM
OK, Electroman. Here's a bit of natural stupidity for you. I have a really nice 30V, 30 Amp power supply and a DVM, but no transformer to test it with...
So, what happens when you put DC through a transformer? I know it's not particularly correct, but what happens?
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: AC coil
10/12/2007 3:55 AM
I know!
Then there's a big BANG and I sell you a new one <Splutter>.
Essex jobs for Essex yobs! <Burp>.
Good Answers: 18
Re: AC coil
10/11/2007 10:10 AM
When did 24VAC rms become different than 24 VDC?
Good Answers: 804
Re: AC coil
10/11/2007 1:45 PM
Uhm, when the polarity started alternating???
Re: AC coil
10/11/2007 2:10 PM
When it started passing energy through capacitors and transformers?
Good Answers: 18
Re: AC coil
10/11/2007 2:34 PM
Yeah, but . . . In ordinary, AC relays which pull a contactor arm down to the top of an armature, the armature has what's called a shaded pole on it, which is virtually a short-circuited turn on the secondary of a transformer thereby causing the primary current to be significantly higher than without the shaded pole through mutual induction. DC of the same voltage does not "see" the shorted turn on the secondary because there is no mutual induction -- e. g. the coil is no longer a transformer. The current in an AC relay coil will actually be a little less in some (depends on the number of turns on the primary coil), and it can be a little more in others, but nevertheless, the currents are close to the same.
In a mercury contactor, there's no shaded pole, and many have built-in rectifiers to create DC. In those cases, the AC current will be less than DC current by about half, so in that case, you're right -- it takes around 10 - 12 VDC to operate a 24 VAC coil. Now, you might say that the coil impedance is a factor, which it is. Inductive reactance of a coil may be higher than the DC resistance, but there are also cases when it's less. Depends on the quality of the magnetic circuit.
Rather than argue about stuff, the best way to check to see if an AC relay coil is O. K. to use with DC is to measure the AC current and use a DC voltage which gives the same current. If heat dissipation from a resistor or zener diode is a concern, 'cause 24 VDC is all that's available, then replace the danged relay with a DC operated one.
Shoulda gone to the trouble to say this earlier . . .
Re: AC coil
10/11/2007 3:25 PM
To be fair ...
I only learned the detailed difference in AC and DC relay coils due to a previous thread on CR4... can't remember who to credit, but I was greatly pleased to be thusly enlightened!
Good Answers: 19
Re: AC coil
10/12/2007 5:32 AM
that was me, thanks.
Re: AC coil
10/11/2007 2:46 PM
Well I did hook the 24VAC coil up and got hot fast, so I unhooked it.
I finally got a contactor w/ a 24VDC coil and used it.
Yesterday I needed to fix the machine asap. so that was the only contactor available in town. Then today I got the correct contactor from the OEM.
Thanks for all your advice everybody!
Re: AC coil
10/12/2007 8:22 AM
Gee it seems the first responder was correct after all, even before all the self appointed "experts" weighed in. Lets hear it for PWSlack...
Good Answers: 18
Re: AC coil
10/12/2007 9:45 AM
If you're talking about me, then gee, I didn't self-appoint myself as an expert, but I do know a thing or two about electromagnetic coils.
Let's do give PWSlack credit for giving a sound answer, but if you're not going to add anything to the discussion, the least you could do is to keep your self-righteous comments to yourself.
Re: AC coil
10/12/2007 8:44 AM
If the coil is only to be energized for very short periods of time (pulsing on and off), it can get you out of a pinch.
It won't last very long though.
Re: AC/DC coil read
10/12/2007 9:23 PM
http://64.233.169.104/search?q=cache:8gwIoSvWIAQJ:www.ascovalvenet.com/pdf/LiteratureRequest/NextGen_WhitePaper.pdf+AC+and+DC+Coil+differences&hl=en&ct=clnk&cd=11&gl=us&client=firefox-a
Out Of The Inner Circle
Re: AC coil
10/13/2007 4:43 AM
I don't know, Why you ask us this question?
Because of nobody tries to use an AC coil for DC or opposite after saw AC and DC coil.
Certainly, It can be used but It can't function properly.
You can try to do it, use contact relay 24 VAC and power supply 24VDC.
Best regard.
Nature is unlimited, human's knowledge is limited
Re: AC coil
10/18/2007 9:07 PM
See also:Relay <http://globalspec.ip09.com/rd/9z1zjh924ietefi92ob5iq8k06g0jj4c874a3h64uqo>
Post #14
Regards
Register to Reply 17 comments
Anonymous Poster (2); Bill (3); Electroman (1); Haajee (1); Hap (1); hemistud (1); HUX (1); JRaef (1); nam70 (1); PWSlack (1); Stinky Pete (1); user-deleted-1105 (2); vermin (1)
