Previous in Forum: AC induction motor control   Next in Forum: Droop, Isochronos speed and Recirculating Current
tube light
10/11/2007 11:58 AM
tube light oprating at 230v/50hz is it possible to operate it on 230v/60hz
Re: tube light
10/11/2007 2:02 PM
Possibly, but more information is needed...
In London UK the tube is the underground system, perhaps you mean a fluorescent tube with ballast?
John.
Re: tube light
10/11/2007 11:27 PM
yes
If all else fails, read the directions. That's if, and only if.
Good Answers: 54
Re: tube light
10/12/2007 1:47 AM
I'm not an authority on this but I think it may function if you don't use the original ballast (which is rated at 50Hz, I believe). Use another ballast with the same wattage rating but for 60Hz.
Somebody correct me if I'm wrong. Preferrably before our friend does what I just told him to!
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
Re: tube light
10/12/2007 2:44 AM
The lamps don't care about the hz if the ballast is electronic, it will work perfectly, if the ballast is magnetic, it will work, but not optimum....
However, a 60 Hz ballast will NOT work on 50hz
Donald
Check out our home page for specs on "Soft Neon"
India - Member - sita rama murthy
Re: tube light
10/12/2007 3:39 AM
yes,it can be made.usually all products are made such that they work on these two frequencies
Re: tube light
10/12/2007 4:23 AM
yes no problem at all
Re: tube light
10/12/2007 4:46 PM
Did you try it , if not try it ,you have to just switch the power supplies and check out
Campbell Lighting (1); Electroman (1); jarunmagnet (1); ktel60 (1); sita rama murthy (1); vikas (1); Vulcan (1)
