Previous in Forum: Logical Conclusion -Sun and West   Next in Forum: Communications tracking.
HVAC - Mechanical
10/12/2007 6:10 AM
hi
1600 LUX lighting load means how many Watts/sq ft.? How could i calculate it? Please help me anyone.
Re: HVAC - MECHANICAL
10/12/2007 6:42 AM
The Lumens per Watt information for the lighting device is required.
Good Answers: 18
10/12/2007 8:01 AM
Type of lamp? Distance from lamp to measurment?
Re: HVAC - Mechanical
10/15/2007 4:07 PM
1 lux is 1 lumen per sq-meter. 1 candle power is 1 lumen per sq-ft.
1 sq-m = 10.76 sq-ft
1 candle power per sq-ft is 1/683 W (for visible light of a freq 540 x 10^12)
1600 LUX is therefore 1600(lumen/sq-m)/10.76(sq-ft/sq-m) * 1/683 = .2177 W/sq-ft
That is the energy of the light hitting the surface. The amount of power required to get that light to the surface depends on the efficiency of the lamp, the lamp fixture (luminaire) and the environment. A metal halide lamp is about 20% efficient in producing visible light. If the Luminaire is 100% efficient, the lighting power is .2177/.20 = 1.1 W per sq-ft. The Luminaire will not be 100% efficient. Reflected light from the surroundings will probably be very small when compared to the source and might not need to be considered.
Register to Reply 3 comments
Bill (1); Howetwo (1); PWSlack (1)
