Previous in Forum: How to measure Amp hour rating of a 18V Lithium Ion Battery   Next in Forum: RF ID Tag
23 comments
Can LEDs emit as much bright light as fluoresent lamps?
10/18/2007 9:38 AM
Can LEDs emit as much bright light as normal fluorescent lamps??!! Can any one please explain how it possible........
Re: can LED emitts as much bright as fluoresent lamps
10/18/2007 9:46 AM
Re: Can LEDs emit as much bright light as fluoresent lamps?
10/18/2007 2:13 PM
If you have enough of them YES!
Expensive though... John.
10/18/2007 9:33 PM
certainly yes.
In fact, its put into use on the market now.
a 100w has been developed and was use for street lighting.
many cars lamp use it instead of tradional lamp.
10/19/2007 5:03 AM
Meanwhile the efficiency is so good that they can emit even more power. Thats one of the reasons for replacing fluorescent backlights for displays by LEDs. Another advantage is that you have less EMI because you need no HV-inverters which must be cross-calculated (combined with lifetime aspacts) to the (this time) higher LED-costs.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Good Answers: 11
10/19/2007 3:41 PM
Plus you can eliminate the mercury which is a miserable environmental problem when the lamp is thrown away. Why the politicians are mandating flourescent tubes instead of LED arrays I can not understand.
The overall costs of LED vs. flourescent vs. incandescent would have to put the LED light as the best option.
Eric
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
10/19/2007 5:07 PM
Because, as usual, politicians, and the mass market, are behind the technology curve. Politicians are mandating fluoresent tubes to replace incandescent lighting, which is even less efficient. Not sure if LED lighting costs have come down to make them competitive with fluorescents, which can be easily justified versus incandescents by longer life and higher efficiency.
Have you seen LED lamps in your home improvement store lately at a competitive cost? I haven't.
"What, me worry?" Alfred E. Neuman
10/19/2007 9:18 PM
YES THEY CAN...I AM A SALESMAN FOR A NEW ENERGY COMPANY STARTING JUNE 2, 2008.
LETS BAN FLOURS AND CFLS AND STOP THE MERCURY POISIONING AND GET ON WITH BEING A SMART WORLD SHALL WE?
BIODIESEL, SOLAR PANELS (3D), LED LIGHTS, BETTER BATTERIES, BETTER FUELS, BETTER LIVING THROUGH ENGINEERING!! LETS DO IT!! I AM! SEE YA IN THE FUTURE!!
10/20/2007 10:58 AM
What markets are you going after?
10/20/2007 11:26 AM
Wel, that's nice, you're starting a new company on my birthday. Will we get an opening announcment with details? Will you be selling in small lots or just wholesale?
thanks & best of luck
AAndy
Re: Can LEDs emit as much bright light as fluorescent lamps?
10/20/2007 9:01 AM
Ca1ic0cat, if you read the technical reports on why compact fluorescent lamps are being encouraged you will see the over the life time of the fluorescent bulb the energy saved is much more than an incandescent bulb, and the power savings at a coal fired power station reduce the amount of natural mercury that they produce by more than the 10 to 20 mg of mercury in each bulb.
So the amount of mercury in the bulb is offset by the saving of mercury being generated by more power hungry incandescent bulbs.
John.
10/22/2007 2:23 AM
I have been playing with white leds since they came on the market in 2000- the benefit of white leds is a white light(not yellow as in incandescent) this is achieved by a phosphor in the led(without would be blue)- as to amount of light, this is directly related to power in/ power out/ efficiency/ heat. If trying to achieve watts of incandescent, for example, the led quickly burns out, as heat can not be radiated as in incandescent(90%)- BUT LEDS have use as personal torch but even there manufacturers use maybe 26 leds, trying to get as much light as an incandescent, but the power consumed is as much!(nice white light though). I personally use a torch with 3 30Cd leds, powered by 3 AAA NiMh cells- they seem to give light for ages(many,many hours)- I have played with inverter circuits that step up frequency to give as much light output from single led (30mA) as 30Cd(95mA), but the circuits take too much power to run, compared to my simple 3 led setup. The bottom line is that everything equates.
10/22/2007 5:45 AM
You wrote at one point:-
which did not factually agree with:-
LEDs do not waste anywhere near the amount power that an incandescent lamp does. Generally speaking incandescents only use about 5% of the power for visible light, the rest goes mainly in IR or heat!!! Halogens use about 1% more for light so are marginally better.....I am told.
As LEDs (only the high power LEDS) actually only get slightly warm, if what you said was true, where is the rest of the energy gone to???
In fact LEDs are far more light efficient but as you pointed out, generally you must use more of them, excepting the relatively new 3watt LEDs will light a passageway as good as a 40 watt Halogen and you can easily read under it.....whether it is as powerful light wise, I suspect someone can prove it is less, but as it does the job just as well who the hell cares!!! The electricity bill has saved 37 watts for each lamp used!!!!
In our bathroom I have a fitting with 7 halogen GU10 (220 volt) fittings. We have replaced 4 Halogens with LEDs with 38 white LEDs per unit and left 3 halogens in place. 7 x 40 = 280 watts before, now we have 3 x 40 = 120 + (4 x 1.4) = 125.6 Watts and the bathroom appears to be lit about the same as before!
There are some folded CFLs which will fit in the same sockets, are warm white (if you wish) and we will also be using more of these in such fittings as with 7 watt power, they give an effective 60 watt light!!
In our halls (3 Cellar, ground floor and 1st floor) we have fittings that brilliantly light up at all levels with a mixture of LEDs and CFLs. We pay for 80 watts when all is lit, but they are as effective (at least!) as incandescents which would have needed about 550 watts.......
My tip is NOT to use halogen fittings with transformers (unless you like having those bare wire versions....), but to go for the GU10 fittings and these you can replace with high power LEDs or folded CFLs easily, whereas with 12 volts, only LEDs are available....
New LEDs are now available (I have not tried them yet!) with 60 LEDs in one bulb!!! The 3 watt GU10 versions are also truly excellent with either 3 x 1 watt LED or 1 x 3 watt LED.....they give (it would appear!) similar light output to a 40 watt halogen.....
I have a little torch with 3 AAA batteries (rechargeable) that runs almost 100 hours with a single 1 watt LED, that gives a really piercing beam for 50 meters or so at night!!!
I suggest to you all that electricity prices will never come down, the earlier you replace as many old fashioned lamps as possible, the bigger the savings possible. Go and buy a few new bulbs and try them out. Sadly a lot of modern fittings use a type of bulb (with bent wire contacts only) that as far as I am aware, have not been made either as a CFL or as an LED......
My wife and I went shopping for new fittings a couple of weeks ago, every one she liked I said no, as it has these strange bulbs, eventually we found a good compromise and two 15 watt CFLs light it brilliantly with an effective 150 watts if they were incandescent.....
Good Answers: 247
12/27/2007 11:27 PM
I've replaced most of the bulbs in the house with fluorescents, but just recently (on my wife's command) replaced the fluorescents in our bedroom fan/lamp with incandescents for the winter. Here in the winter it is always colder outside than a comfortable room temp , so any "waste" heat is not wasted -- it warms the house. The real reason, of course, is that the fluorescents take so long to come on.
12/28/2007 8:43 AM
Really? How long is "so long"? One second, two seconds, three? Except when a CFL gets really old and is about to die, I have noticed a lag of only 1-2 seconds, sometimes less, almost instant with some CFL's. Isn't the energy savings, and the less frequent bulb changing worth far more than the slight nuisance of a short lag in "on-time"? It certainly is for me!
Also, unless you heat your house with resistive electrical elements, you may indeed be wasting some energy in partially heating your home with incandescents. Even an electric heat pump would be more efficient. LP, natural gas, or even oil should be more cost effective than electricity, unless you live in an area abundant in cheap hydro-electric power sources. In rural Scotland they still burn peat which smells nasty (I guess you get used to it) in room fireplaces and some furnaces because it is basically free. All it costs is your time and effort in cutting and stacking it to dry every spring/summer. Of course, it probably isn't very good for carbon reduction!
12/28/2007 11:49 AM
A good Scottish whisky made with "Peaty" water is a fine thing on a cold night!!!
12/28/2007 11:47 AM
A very good point!
12/22/2008 12:27 AM
See here: www.elecosn.com
Here are dimmable LED Bulb, and LED incandescent bulb
10/22/2007 1:02 PM
Burning LEDS is the consequence of having made a bad thermo management and so wasting a lot of money for expensive unsafe operated parts. As in all semiconductor devices reducing their sizes leads to thermo stress which has to be accomplished. Especially LEDs with their high output power (optical and, because of their excellent efficiency, electrical, too) need a sophisticated mounting. New and expencive materials like aluminium nitrid are the answer on this challenge. Only "Playing" with these parts means burning fingers, you can only avoid this by a rugged construction which is able to dissipate as the application requires this.
11/01/2007 9:44 AM
Go to website ddpled.com.
they are based in california.
thay have a world of solutions.
Learn more, Do more , Be more
02/19/2008 1:04 PM
The measure used to determine light output is largely mis-understood. Of the choices, the most common unit of measure is the lumen. The best light sources produce over 100 lumen per watt. LED's can do that, but you need a lot of them to produce the thousands of lumens that a fluorescent lamp produces. LED's have been used for street lighting in Europe since 2004 or 2005. We have them in most of our stop (or traffic signal) lights now. With the advent of the multi-color (multi-diode) LED in a single die, we now have multi-color LED signs that just turn on various diodes to create any color you want. Imagine mood lighting where you can change from warm white (like an incandescent) to bright white (like daylight). You can't do that with a fluorescent because the powder determines the color.
12/22/2008 9:43 AM
I wonder if that's how Morimoto's restaurant in Philly does their color transitioning. All the booths are sheeted in translucent white plastic and illuminated from inside the seat. The colors definitely change but it's almost impossible to actually see them change. It's the smoothest transition I've ever seen. Tri-colored LED's could do that... I think...
12/22/2008 8:47 PM
its very easy job.
some of them are white color led, others can be cosist of two color, three color leds can consist of all kind of color for a pic. but attention, three color led pic is not consist of only three leds, but four leds in a set usually.
12/22/2008 8:43 PM
In the lab, we can do the led at more than 100lm/w, but in practice its only 60lm/w in average.
Many led street lamp are coming from China. they are consist of 100 or 200 or more led bulbs in a set to get more brighter lignt and more save engery than other lamp. but to get an ideal warm white color is still a problem. most of the white led has more color temperature.
I dont know other countries, but our cities in China are almost led traffic signal lamp.
its easy to get a pic by arrange led as matrix range.
Register to Reply 23 comments
AAndy (2); Andy Germany (3); Anonymous Poster (5); Blink (1); ca1ic0cat (1); cnpower (3); djacob (1); Electroman (2); Neil Kwyrer (1); STL Engineer (2); uweka (2)
You might be interested in: Lamps, Light Emitting Diodes (LED)
