Previous in Forum: Help With a Calculation   Next in Forum: Direct Steam Injection into Cooling Water Line at Pump Suction
11 comments
Gasket Compression Calculation for a Known Load
09/08/2019 10:43 AM
I want to calculate gasket compression for a known load. Gasket is spiral wound, ss304 with graphite filled. All dimensions of gasket are known. Or else, if compression is known, calculate load on gasket. Neglect internal pressure.
Re: Gasket compression calculation for a known load
09/08/2019 8:22 PM
You have your load and area of contact. but you need to know the compression characteristics of the gasket and the internal load...
https://www.garlock.com/sites/default/files/files/technical_articles/Initial%20Gasket%20Compression.pdf
Re: Gasket Compression Calculation for a Known Load
09/09/2019 3:01 AM
One cannot neglect internal pressure, as it has an effect on the tension in the bolts, which has an effect on the pressure in the gasket.
"Nurse! The screens!"
09/09/2019 4:23 AM
It must exceed the pressure in the pipe, otherwise the joint will leak.
Good Answers: 137
09/09/2019 5:08 AM
ASME VIII contains detailed flange/gasket calculations.
09/09/2019 6:24 AM
...which means that there is no need to carry out a <...Calculation...>.
Good Answers: 137
09/09/2019 10:43 AM
Not with you there. I don't have ASME VIII with me, but I have an old vrsion of BS5500, which has a similar flange design procedure. I would guess the latest Euronorm has something similar. There are quite a few calculations to arrive at inputs to the Suggested working form.
That's for the complete flange and gasket design. Not clear just what the OP is after, but I doubt it's as simple as him knowing the total bolt load, as in that case the gasket stress is easy to work out. But it's still a calculation.
09/10/2019 3:58 AM
Can we use stress strain relation . Is there any approximate Young's modulus value that can be used int this relation. Gasket is spiral wound, ss304 with graphite as filler.
09/10/2019 6:28 AM
<...Gasket is spiral wound, ss304 with graphite as filler....>
That was already stated in the Original Posting to this thread.
09/10/2019 6:41 AM
A1) The capabilities of correspondents are not in the domain of this forum to judge.
A2) Yes.
Good Answers: 137
09/10/2019 6:48 AM
In a spiral wound gasket the section of each "wire" is likely to be chevron-shaped. Using beam-bending theory you could estimate the stress/strain relationship. It will be much smaller than the Young's modulus of the 304SS material.
But why do you need to know? For eg a 3mm thick gasket the compression will be small, even for a large stress.
09/10/2019 7:09 AM
See #4⇑.
Register to Reply 11 comments
Codemaster (3); IRSHAD (1); PWSlack (6); SolarEagle (1)
