The plasma torch is quite a bit faster but also is size dependent, ie. it comes in several different power levels rated for metal thickness. The Acetylene torch is only supplied in a couple of sizes. The plasma torch also cuts anything such as stainless or aluminum whereas the acetylene torch only cuts plain steel because it depends on oxidization burning.
