Previous in Forum: Synchronizing Pneumatic Telescopic Cylinders   Next in Forum: Improvising, Where Necessity is the Mother of Invention
18 comments
Material for Impeller ID Fan for Coal Fired Heater
03/19/2020 8:46 AM
Hey. I want to inquire about the material that would be the most suitable for impeller and cone of an ID fan installed for flue gas of a Coal Fired Heater.I am facing an issue of wearing and abrasion and i want to eliminate that. Currently I am stuck between SS 304 and SS 2205. What other options can i possibly explore. Thank you!
Re: Material for Impeller ID fan for Coal Fired Heater
03/19/2020 8:53 AM
Well, there are as many options as there are materials. The forum needs to know:
  • the original equipment manufacturer [OEM] 's material, and why is that material currently deemed unacceptable
  • the nature of the discussions with the OEM and the recommendations received during those discussions
to form a view.
The nature of the fluid passing through the <...impeller and cone of an ID fan...> is of immediate interest, including its temperature and pressure, as is the condition of any upstream solids removal equipment, on the basis of the <...wearing and abrasion...> taking place. The issue of <...eliminate that...> might be something other than the <...material...for impeller and cone...> in that respect.
What has been withheld from the forum is possibly of more value than that which hasn't.
03/19/2020 9:22 AM
The OEM material is SS 304. The material is deemed unacceptable because of the increased erosion at the impeller and the cone of the ID caused by the Flue gases from the coal fired heater. The recommendation received is changing the material to SS 2205. The temperature of the flue gases is about 220 Degrees. Flowrate and pressure are not known. And there is no upstream solid removal equipment. Thank you.
03/19/2020 9:26 AM
What is the frequency of change of the <...SS 304...impeller...>, and why is this <...unacceptable...>?
What is it that makes <...SS 2205...unacceptable...>, given the answer to the above?
03/19/2020 9:58 AM
03/19/2020 10:53 AM
03/19/2020 12:21 PM
03/19/2020 1:04 PM
I would just step up the hardness of the material, which has to do with heat treatment and composition, so which grade is the hardest....?
03/19/2020 7:24 PM
03/19/2020 11:29 PM
Other suggestions seem to suggest an improvement in corrosion capability, but not erosion, which is what the application would suggest. One solution for erosion is a soft resilient coating, so particulate impacts deform the coating rather than scour it. Never seen this on a fan, though. In hot mineral processing, carbide plating is used to extend the life of high friction areas. I would look at coal pulverizer metallurgy, as the conveying equipment sees an order of magnitude higher particulate loading, and usually operates at higher tip velocity.
Most of the ID fans I’ve had to apply were installed on the clean side of pollution control equipment such as electrostatic precipitators, so erosion was not a big factor.
Also, we might assume DegF for your temperature, but best not left to imagination...
Good Answers: 58
03/20/2020 5:34 AM
Agree that soft resilient coatings are worth looking at for erosion, but I would assume that in this case the OP is talking Centigrade.
Corrosion at 200o C should not be a major issue.
Abrasion resistant wear plates would be my first choice, but these require a redesign of the impeller.
Simpler would be a tungsten carbide coating in the erosion affected areas (prior to balancing).
Good Answers: 38
03/20/2020 4:44 PM
03/20/2020 9:21 AM
The OP said nothing about <...corrosion...>.
03/20/2020 10:50 AM
Yes, that was the point. The 2205 alloy suggested offered corrosion improvements...
Re: Material for Impeller ID Fan for Coal Fired Heater
03/20/2020 6:12 AM
With the info you supplied,... if you want to stay with stainless, 310 would be more abrasion resistant than 304, I don’t know if it’ll be enough to make a difference.
i had done some research on this for material for use in a cyclone that use use abrasive material that was 304 SS. It was hold up pretty good (better) with 310ss, that was 7 years ago, and there are fewer ‘repair patches’ with the same amount of use. 24/7
I’m don’t have the metallurgical background require here to make Equivalent or better material to be applied here, the SS2205 with its ferrite content may able be harden, but I’m sure it’s done already.
03/20/2020 6:37 AM
S S 304 is very weak material against abrasion,
Use Nickle hard material,it will corrosion resistance, heat resistant & has good wear resistance normally used in Cement Industry.
03/20/2020 6:52 AM
Yes, and thanks for the comment.
As I understand and posted, 310SS is slightly better for being abrasion resistance, but it is uncertain, if it’s enough to make a difference.
03/20/2020 2:27 PM
I've always found unobtanium to be the ideal substance to use under nebulous conditions.
03/20/2020 8:01 PM
Stellite 6B should do it.$$$$
https://www.stellite.com/us/en/home.html
Hard surfacing of the high wear areas with Stellite 6B is recommended.
Register to Reply 18 comments
Anonymous Poster (1); HiTekRedNek (1); MJCronin (1); Muhammad Zafar Iqbal (1); phoenix911 (2); PWSlack (4); redfred (1); Rixter (1); rwilliams (2); Saad419 (1); SolarEagle (2); The Prof (1)
