Previous in Forum: Cannot Find a Specific Form of Pump's Inertia Equation   Next in Forum: Standard Temperature, Pressure and Process as well as Environment for Liquid Filling Line
24 comments
Good Answers: 19
Industrial Gas Rates
04/09/2020 11:35 AM
Hi,
Please tell me the Industrial Gas Rates at Edmonton, Alberta, Canada:
a) C$/ m3?
b) C$/ mmbtu?
Formula to calculate cost C$ steam/kg assuming Boiler on natural gas operation 10,000 kg/hr at 10 bar with feed water at 90C working on both above m3 & mmbtu ratings.
Thanks
Re: Industrial Gas Rates
04/09/2020 2:12 PM
This sounds more like a Google question than a question for a public engineering board. I expect it will also vary wildly depending on available local infrastructure (piping or trucked) and expected consumption rate.
Good Answers: 19
04/16/2020 6:35 PM
It seems you have supporters to give you the "Yeh"/ thumbs-up on a Good answer when practically you answered nothing!!!!
04/17/2020 8:11 AM
Do you feel better now that you've ridiculed me and those who like my answer? Good.
So sad.
04/09/2020 4:08 PM
Good Answers: 19
04/09/2020 4:46 PM
When I ask a question like that it is obvious i've searched Google first.
$2.40/ Gj > how to convert to mmBtu? or m3/hr? or KWH?
6.8 cents/KWH >how to convert to mmBtu? or m3/hr?
Show me . Don't direct me to Google.
Then please show me formula to calculate steam cost/kg.
(please note this has nothing to do with pipeline transmission or whatever)
Thanks
Good Answers: 25
04/09/2020 5:25 PM
1GJ = 947817 BTU See here
1GJ = 277.278 KWH See here
All the conversions are listed here
You obviously didn't try very hard with the google search. It took me about 30 seconds to come up with the previous information.
To calculate steam cost/kg boiler efficiency must be known. You have not given that information.
While pipeline transmission won't affect conversion rates, it will certainly have an effect on price which is what you asked for in your original post.
You will find that you will receive much better help here if you show you have put in a little effort.
Troy
04/09/2020 6:57 PM
Fuel Consumption = steam quantity* latent heat / Efficiency * Calorific Value
Good Answers: 19
04/10/2020 2:54 PM
Efficiency 90%. Does this help.
1GJ = 947817 BTU - Know this . What rate is C$/mmBtu?
1GJ = 277.278 - Know this . What rate is C$/KWh?
So how much is cost steam C$/kg?
04/10/2020 4:35 PM
04/10/2020 11:17 PM
04/12/2020 3:46 AM
The simplest way to calculate steam costs is to gather the facility’s cost data, which is site-specific, commercially sensitive and highly unlikely to be had from a global Engineering forum, and divide it by the steam generated over the same period.
04/12/2020 11:03 AM
It also depends greatly on what one will do with the steam, another fact not evident. Heating a duplex in the winter will be vastly different from autoclaving facilities in a hospital, electric power generation or an atomization processes.
Speaking of boiling water, I think I'll make myself some Earl Grey tea.
04/10/2020 3:53 PM
OK, let me try a different tack here and maybe this sail can catch wind.
You wish to pay somebody in Canadian dollars for this gas, who? (I don't work for anyone in Canada.)
What do they charge per cubic meter of gas at STP?
How many thermal calories are in that cubic meter?
It takes 540 calories to boil one gram of 100°C liquid water into 100°C steam.
How hot is the water you wish to boil?
How hot do you need your steam?
Good Answers: 19
04/10/2020 5:46 PM
Cost Natural Gas is $2.40/ Gj
My question: > how to convert this $2.40/Gj to C $/ mmBtu? orC$/ m3/hr? or C$/KWH?
6.8 cents/KWH \
My question >how to convert to this $0.68 cents to C$/mmBtu? or C$/m3/hr?
Good Answers: 19
04/11/2020 11:15 AM
I find all my old Gurus just giving me diplomatic and political answers.
I am giving you all the rate Natural Gas in Giga Joules as C$2.40 / Gj and
$ 0.68 /KWH
YET NONE is converting it to C $/ mmBtu? or C$/ m3/hr? or C$/KWH?.
Don't send me conversion factors/ tables JUST let me know what $ rate it converts to in mmBtu/ m3/KWH if you can.
I've done my calculation and just wanted to double check but so sorry to find my most over 1.4 decade friends giving me toally merry-go-around answers. So sorry.
Good Answers: 19
04/12/2020 10:56 PM
PWSlack if you dont't understand the English or my question stop beating around.
Good Answers: 25
04/13/2020 6:49 PM
If cost is $2.40/GJ and 1 GJ = .947817 MMBTU then cost per MMBTU is $2.40/.947817 = $2.53 per MMBtu. If your boiler is about 90% efficient then $2.53/.9 = $2.81 per MMBtu.
You still don't give enough information to give an exact answer but making some assumptions on feed water pressure and assuming 10,000 kg/hr of saturated steam, we can estimate about 22 MMBtu/hr or roughly $62 per hour.
Troy
Good Answers: 19
04/13/2020 8:16 PM
Troy,
My old friend BIG thank you.
COST OF GENERATING STEAM@ CANADA 2020:
22,000 lbs/hr (10,000 kg/hr) at 150 psi
150 psi > 1195 Btu Enthalpy
Feed water 90C > -162 Btu
= 1033 Btu/.90
= 1147.8 Btu at 90% efficiency
Calorific Value Gas 1000 Btu
Rate 2020: $ 2.53/mmBtu
22,000 x 1147.8/1000 = 25251.6 Cft Gas required
MmBtu = 25251.6 x 1000/ 1000000 = 25.25 mmBtu
Cost Gas / mmBtu = $2.53 x 25.25 = $63.88/22,000 lbs
= $0.0029/lb Steam
= $2.90/1000 lbs Steam
= $6.39/Ton Steam
=$0.0064/Kg Steam
Please check if OK.
Thank you again.
Good Answers: 25
04/14/2020 9:54 AM
That looks about right to me, but I am no expert and it really isn't my field so if this is something critical or really important I would have someone you know you can trust check the numbers.
Troy
Good Answers: 19
04/14/2020 12:16 PM
Thank you Troy you've always been helpful.
Same old friends others too but possibly with age they've become sarcastic. Very sad.
04/11/2020 2:46 AM
None of it takes into account the maintenance and depreciation costs of the installation.
Because all of this is installation-specific, and financial information is commercially sensitive, this is why this forum deals with technical issues, leaving finance ones for processing by the facility in question instead.
04/11/2020 2:48 AM
This information can be obtained by contacting the gas suppliers in those districts directly. The correct tool to use is the telephone.
Good Answers: 19
04/11/2020 11:26 AM
Thanks. How silly of me i may be living in a jungle and did not know that?
Actually most of my old friends retired from engineering calculation and this is one of the reason I left CR4 for over 2 years and find nothing has changed. Thanks and no thanks for your political answer.
04/12/2020 3:03 AM
The forum does not have the telephone numbers in question nor the incentive to make the calls.
Register to Reply 24 comments
ducon (9); PWSlack (4); redfred (4); SolarEagle (4); Troy36 (3)
