Previous in Forum: Lightning Arrester Selection   Next in Forum: How Do I Fix the Rectifier Voltage Fluctuation in CEG AC UPS?
Motor Terminal Overvoltage in Steady State by Using VFD in ETAP Analysis
05/09/2020 12:59 AM
Dear CR4 forum members,
When I analyze motor starting by using VFD starter with ETAP software, I found voltage level at switchgear bus is still nice & only small voltage dip happened. But I shocked when I found the motor terminal voltage level to be 220% of nominal voltage until steady state condition. I analyze big motor rating (315 kW, 400V) with high torque load (such as conveyor).
Any CR4 member ever have similar case with me? Any explanation why this overvoltage happened continuosly until steady state condition? Is it possible?
Many thanks,
ATOM, Indonesia
Re: Motor Terminal Overvoltage in steady state by using VFD in ETAP Analysis
05/09/2020 1:22 AM
05/09/2020 3:25 AM
GIGO perhaps?
05/12/2020 7:13 AM
Re: Motor Terminal Overvoltage in Steady State by Using VFD in ETAP Analysis
05/09/2020 10:37 PM
If you reversed the sign of the conveyor load, it might look like an induction generator, which would cause the voltage to be very high. In the real world, decelerating a heavily loaded conveyor too quickly can cause overvoltage.
There has to be something wrong with the input parameters, in any event.
05/16/2020 2:20 PM
Well, that's nonsense. So something is wrong with the model in the <...ETAP software...>.
Anonymous Poster (1); PWSlack (1); rwilliams (1); SolarEagle (1); Tornado (1)
