Previous in Forum: Slipring Contacts   Next in Forum: Replacement of Transformer
Contractor Coil Voltage
05/15/2020 6:52 AM
Hi all
in one of the projects, we have a 6KW 415v Split Ac for cooling of Panels and a rectifier circuit.
we have used Main breaker, 3phase Overvoltage and undervoltage protection relay - a 4p contactor - after that supply is split and has Mcb and rcb combo which in turn will connect to the Split Ac and rectifier circuits.
the logic here is whenever voltage is normal , contactor will be closed and power the AC and Rectifier circuits and in case of overvoltage/ undervoltage They are shutdown
It is also controlled thorough a controller which takes all the input and has the ability to trip the main breaker
I was going through the circuit and I found that the OV UV relay is powered From mains 415vac and then it is used to power a 230V aux relay. the contacts of this relay is wired to the 24vdc coil of the contactor Which will do the switching and power the AC
Now the question:
can we not optimise this slightly complicated system
any ideas would be appreciated
Re: Contractor coil voltage
05/15/2020 7:14 AM
There are usually no extra controls in a system....what you want to ask yourself is what will change if I remove this part of the system...everything is usually there for a reason, unless the system has been modified in some way from its original design ...
Re: Contractor Coil Voltage
05/15/2020 1:34 PM
Optimized for what; lowest or highest parts count, reliability, profit margin, flexibility, standardized parts, cooling, heating, accurate failure mode detection, other?
05/15/2020 11:43 PM
It is likely that the rating of the voltage sensing relay output is not robust enough to handle reliably the 24v trip coil current & especially interruption. The interposing relay also adds the possibility of remote monitoring of the equipment, as an option for the upgraded version of your equipment.
Good Answers: 19
05/16/2020 12:27 AM
It’s general practice to have all trip circuits and protective circuits in 24 V, independent of source.
The existing system is best with out any interference from AC source.
In this case for any over voltage the contractor coil will not get damaged.
Ramesh,Freelance Electrical/automation Consultant
05/16/2020 9:10 AM
There seems to be a suggestion in this thread that it is not even legitimate to ask: Is there a simpler and more elegant method to achieve the same result? Opposition to the posing of this question is an odd attitude to find on an engineering forum - the attitude that this is the way it is done, the way it has always been done, and there is no better way to do it. The question of the original poster is specific to an electrical control circuit, but regardless of the field of endeavor, the question, taken in its generality, is the question that drives innovation. The majority of granted patents make no claim that they accomplish what has never been done before, but that they do exactly what has been done before, but in a simpler, more elegant manner.
05/16/2020 1:39 PM
<...the OV UV relay is powered From mains 415vac and then it is used to power a 230V aux relay. the contacts of this relay is wired to the 24vdc coil of the contactor Which will do the switching and power the AC...>
The simplest system would be to do away with all that rubbish altogether, and simply lob a suitably sized crowbar across the open-circuit conductive parts when an electric circuit is needed. That would work too.
What <...we...> does is regulated by the end Client's construction standards. The word <...we...> indicates there is more than one at that location. So why not discuss it among the rest of the <...we...> instead, and find out why it has been done that way, straight from the proverbial horse's mouth?
The forum knows nothing about the Client's standards, because the <...we...> has deliberately withheld this information from it.
Go figure.
canadianslidewinder (1); PWSlack (1); ramvinod (1); redfred (1); rwilliams (1); SolarEagle (1)
