Previous in Forum: Charge in Parallel, Discharge in Series   Next in Forum: Any Coin Collectors????
CFD for Gas Detection Study
06/08/2020 10:46 PM
Dear CR4 community,
I need your assistance concerning the requirement of CFD modelling, shall it be carried out when designing gas detection systems related to the Hazardous Area Study.
Is that mandatory by the CODE such as API RP 505 or any other API RP that stated not necessarily required due to the gas properties?
Re: CFD for Gas Detection Study
06/09/2020 8:40 AM
<Sigh>
The first step, surely, is to have <...CODE such as API RP 505...> to hand. Please respond after that has happened.
06/09/2020 9:19 AM
Depending on the classification of the gas, I believe it is assigned a minimum area for safety, as for placement of gas detection sensors, that is usually determined by cost analysis...
https://www.researchgate.net/publication/321762153_A_risk-based_methodology_for_the_optimal_placement_of_hazardous_gas_detectors
06/09/2020 11:47 AM
I'm certain this will change greatly on this unstated location. Similarly, CR4 should not be considered your Authority Having Jurisdiction (AHJ) regardless of where you or this installation resides. You will save yourself many steps by contacting them and asking them about this code. Now if the AHJ reply baffles you, then you can bring us both their reply and the relevant code (in verbatim) and we will gladly assist you to comprehending what is meant.
Good Answers: 125
06/09/2020 3:35 PM
Some gasses are heavier than air, some lighter. This plays a large part in where the detectors are located.
Air movement is also a big factor.
Go find a gas detector manufacturers rep or a contractor who deals in these systems. They will help you lay it our for free.
I supply these system all over the world and I have never seen an AHJ who knew anything at all about gas detection. The Insurance guys sometimes know a little, but they will only get involved a small fraction of the time due to the liability of even small design changes.
Register to Reply 4 comments
PWSlack (1); redfred (1); SolarEagle (1); WJMFIRE (1)
