Previous in Forum: Fixing Plastic Sheets on Old Brick Walls in House   Next in Forum: GPS Coordinates
49 comments
Father's Bridge
09/12/2020 9:45 PM
My father has asked me to help him build a bridge on some new property he bought, I have the design mostly figured out I just need guidance on what size beam would be appropriate. We will need it to hold gravel trucks for continuing the new road construction. From abutment to abutment, it is 50'. Concrete abutment on both sides, 12' wide, 5 beams to span the distance, the 2 beams on either side where the tire hits, will be closer to the edge to support the Treated 6"x4" deck, or maybe 6x6 now that I think about it. X bracing every 10' across.. What size l-Beams will I need to span the distance?
I'm also open to any better way/design to build it.
Thank you for you time.
Tyler Bingham.
Pathfinder Tags: #Bridgespan
Re: Father's Bridge.
09/12/2020 10:20 PM
I'm not a civil engineer but you are making me nervous. You've not indicated at all what type of bridge design you are thinking about using. You claim to have a design already planned but you ask our opinion on the size of the I beams without indicating at all what type of beam loading you expect, let alone what magnitude of loads on this beam other than it will hold "gravel trucks".
Hire a licensed engineer.
09/13/2020 12:13 AM
A bridge?,... first off, what is it crossing,... is it a ravine! ditch or is it a navigable waterway? (Review Section 329.8 to 329.16)
have you checked on if any permits are required, or even if an environmental study is required...
09/13/2020 7:51 AM
Simple mistakes have caused bridges designed by engineers to collapse.
I cannot imagine how many problems would happen in your unspecified design.
The best thing I could advise,IF I were to offer advice, is to get an engineering firm to design it.
This is not a weekend warrior project.
In lieu of that,buy an old railroad flatcar from the scrap yard and use it as the bridge.
They are usually about 80 feet long,so plenty to bridge the gap; And have an engineer design the abutments.
Do it once,and do it right!
09/13/2020 12:45 PM
We have decided to use a rail car. I am a General Superintendent for an ironworking erection company specializing in infrastructure and have worked hand in hand with structural engineers and have a been doing construction for over 20 years. I'm not just going to slap some steel together and think it's going to work, I have built bridges in connecticut, alaska, and California and am currently putting a railroad across a floating bridge here in Seattle, I am very familiar with bridges and have built a few out of timbers that's were never engineered spanning over 35'. I see everyone is concerned with this question, I may have not given enough information initially. Either way we purchased a 56' rail car rated for 100k . Should have no problems. Install will be easy. Thanks for the advice and concerns. Maybe I'll see one of y'all in the field building America. ����
09/13/2020 2:22 PM
You will build an heirloom,that will still be used when your great grandchildren ask their dad about it.
Glad I could help.
Good luck!
09/13/2020 5:49 PM
You should make a video of the entire process....that would be cool...or get someone who would like to make a video record...good for family gatherings..You could share some pics here, we love that kind of stuff....
Good Answers: 125
09/15/2020 3:51 PM
That should work but it's close.
An 18 yard dump truck loaded with gravel will approach 80,000 pounds.
09/13/2020 8:17 AM
I like an arch design...
....or I guess you could buy some prefabricated bridge spans....
https://truenorthsteel.com/bridge/vehicular-bridges/
09/13/2020 8:50 AM
Hey look, design tool...
Fun for the whole family....
https://usbridge.com/
09/13/2020 9:08 AM
09/13/2020 9:38 AM
The reason I mentioned flat cars as a bridge was that I read where,after an earthquake,the engineers were looking for a quick way to replace bridges.
One of the young engineers suggested using flat cars for the spans.
After due consideration,they decided that it was a suitable replacement for the spans,an only needed the abutments to be rebuilt.
Just think about the stresses and shock loads a flat car has to survive for many years.
It would not be smart to design a bridge the same as a flat car,because they are
over built for this purpose,but if you can buy one for scrap price,why not?
Modern bridge designs are built for max economy of materials and labor and durability,strength.
09/13/2020 10:00 AM
Step right up and take a gander at our wide selection of premium used stock...
Just $23k ...+ additional shipping and handling charges may apply...
Seriously how am I going to move this? Let's see, where's the nearest railroad yard...weighs a little over 40k lbs+ a mere 89 ft long....? logistics...
09/13/2020 10:18 AM
Ah here we go with the wooden planking...70k lbs...just cut it in half and weld them together side by side...
09/13/2020 11:17 AM
Flat cars also come in 60ft lengths.
09/13/2020 11:14 AM
It doesn't matter how you do it,it is not going to be cheap.Perhaps culverts?
Not much information given.
Here is a link to an awesome flat car bridge:
https://www.redi-rock.com/build-design-road-bridge-railroad-car.htm
09/13/2020 9:44 AM
The abutments are the most important parts of a bridge,If they fail,the whole bridge fails.When blowing up an enemy bridge,they are taught to start with the abutments first.If you blow up the middle,there is a smaller gap to bridge.If you destroy the abutments,they must start all over.If using 2 or more flat cars,join them on an angle to transfer load to the ends.(Create an arch).
09/13/2020 10:02 AM
If you insist on doing it with timbers,use this image as a guide:
Or this one:
09/13/2020 12:07 PM
You could just lay a big pipe in the middle and fill it in with rock and gravel...
...or something like this....
https://bigearthsupply.com/product/12-24-rip-rap/
09/13/2020 12:18 PM
Culverts(pipes) are available in HDPE plastic of many large sizes to handle just about any load or size.Might be the best bet yet.
09/13/2020 12:30 PM
09/13/2020 4:26 PM
HDPE culvert pipe does seem to be the best way to go...
https://online.ogs.ny.gov/purchase/spg/pdfdocs/3770022719Cat_ISCO.pdf
09/13/2020 11:01 PM
Tyler
i think you could get some used i beams I've used 24" tall 8. " flange 5/8" thick beams for a similar project I would park three concrete trucks on that span ( exaggerated ) but those type of beams carry a lot there is an exact math to calculate their capacity ( look at a parking garage) but what you were referring to using a railroad body makes sense think how much wieght they can carry. I bought mine for a couple hundred each from a guy that Demos buildings and took them on a 50 ft flatbed easy . If your worried put 3 or 4 but loggers do this all the time and run 100,000 lbs all day , just find a local demolition company or steel scrap yard , new might be too expensive remember scrap is very cheap these days. Good luck buddy
Lighten up
09/13/2020 11:56 PM
You do not give anywhere near enough information for even an educated guess.
OK, you can assume maximum legal road limits for GVM (Gross Vehicle Mass) but where I am is 100% certainly going to different to where you are.
OK, you mention abutments, but how can they be designed if you don't know the beam required for the span?
What is the distance between the top of the bridge and whatever it is crossing? As "phoenix911" said ",... is it a ravine! ditch or is it a navigable waterway?" and I would add another road or a flowing creek/river/stream?
What is the clear distance required between the underside and whatever is underneath the bridge going to be?
Why 5 beams?
As "redfred" said "Hire a professional engineer"
Re: Father's Bridge
09/14/2020 7:56 AM
This is very well worth the visit should any of you be in the area of North West PA!
Re: Father's Bridge
09/14/2020 9:43 AM
There is not an abundance of information presented. How about some photos of the area to be spanned, what is the weight of the loaded trucks, also what are the earth conditions at the abutments for a start. Possibly a properly sized culvert would do the job?
Re: Father's Bridge
09/14/2020 12:52 PM
A 50-foot-spanning bridge, to convey heavily loaded motor vehicles across it, is way more than just a casual ''back yard'' job.
Do it right, by starting with hiring a licensed structural engineering firm, and following their advice, before you hurt anybody...
Re: Father's Bridge
09/14/2020 6:20 PM
Just think of what needs to retain the foundations,... as in soil compositions,... is it sand?... that’s trouble... clay?,... almost as bad as sand. Gravel?,...
Going off topic,... back in the 80’s, I looked into a PE license,... They listed some of the answers given That were ridiculous... an example, I don’t recall how it was framed, but it was some thing like this...
to figure out the stresses on an amusement ride, a loop on a roller coaster I believe.
The applicant responded that he never did any calculations... his claim was,... you make sure you’re going fast enough through the loop before anything happens...
i still don’t believe it,... in the years since, what I experienced with some engineers I’ve worked with (and some with PE’s )... this may have happened..
Re: Father's Bridge
09/15/2020 11:33 AM
As a Registered Civil Engineer, I have to regretably agree...
GA from me for an answer that's not too far off topic, imho...
Re: Father's Bridge
09/15/2020 12:55 PM
I appreciate the humbled response...
I tend to come of strong to a point of offending the more weaker ‘professionals’ especially the academia types.
Re: Father's Bridge
09/15/2020 3:21 PM
Thanks, I try to be a Sargent-Joe-Friday-type of Civil Engineer (i.e: Just the facts, (man), just the facts.)...
The OP seeems to have been lucky, so far, (improvising) certain bridge-type structures, but, operating suchly as a bridge designer is un-ethical, to say the least...
Luck is nice to have, while it lasts, but it never lasts ''forever''...
Re: Father's Bridge
09/16/2020 1:38 PM
Phoenix911, it seems that GA's do not, in some cases, last very long, either...
...and, that actual freedom-of-speech fades one more little bit when each GA ''fades'' too......
Re: Father's Bridge
09/16/2020 2:34 PM
I understand, personally, that doesn’t bother me,... it normally comes from the ‘cancel culture’, which on this site also happens to consist of weaker ‘professionals’ especially the academia types.
I seen it lately, and I’d point it out.
I look at them as my groupies, I’ve noticed they also like to stroke each other, Because the adage misery likes company.
Anyways, when they go Off Topic on posts, I know the cohorts are reading and still following me. I use it almost like a barometer, more times then not,... when marked OT, it means I’m on the right path, Especially when there are still those that would cancel the OT with a GA.
Currently waiting for this post to be marked off topic... lol
Re: Father's Bridge
09/17/2020 11:18 AM
Here's a GA to make up for the one that was (negated) on
Re: Father's Bridge
09/17/2020 11:43 AM
...post #26.
Re: Father's Bridge
09/17/2020 5:17 AM
As my ol' Pappy used to say"If you throw a rock into a pack of dogs,the one that gets hit will holler?"
What's worse is when you see these :engineers" in a real job that requires real knowledge and are very dangerous,especially electrical engineers.I have met a few that, if they were engineers,the woods are full of them.
I have also met several technicians that were more capable than engineers at solving highly technical problems.
They had no degree,just learned on the job over many years of experience.
They probably could not pass an engineering exam,but demonstrated skills and knowledge far above their pay grade.
Re: Father's Bridge
09/17/2020 9:32 AM
this is going off topic,... but it’s interesting.
I was an engineering manager, I had designers with associates degrees, when they had engineering responsibility... (now it’s a grey area between the designer and engineer) And I’d review their work and projects,
and the end result, the designers project were more successful, Fpfor the most part, initially and the results.
The reason I’ve found, is that they were humble, because they know they could be wrong, And they checked their work, also they also had more practical experience, by knowing where to apply their ‘resources’ on areas that matter.
i also had well educated engineers, That would spend and ungodly amount of time on items that wouldn’t make no different whether it passed or failed. The project would be over budget, and the performance would be borderline. Where I had to pull them off the project and reassign the project, depending on the situation even pick it up on my own.
Now, not all designers or engineers are that way... but when your in an OEM environment.... I tend to lean towards the practical person whether it’s an engineer or designer.
Now an engineer or designer, your always balancing a project objectives, with its budget, performance, schedule, manufacturability, maintenance ect... and its a compromise. And when I interview people for a new engineer or designer, I’ll ask one question, when you weight all the objectives, not giving them choices, What is the top priority, not once do they say safety. I thought that’s was Interesting.
Re: Father's Bridge
09/17/2020 1:56 PM
The first question I always asked was what was the top priority.
If they did not say safety,I was not interested in anything else they had to say.
An unsafe worker is the most expensive worker you will ever have.
I always held a safety meeting every morning before work began,even though it was boring and repetitious to most,kept MSDS books readily available and conspicuous,and made certain everyone was familiar with LOTO procedures on the equipment they were using,had proper PPE Gear according to location and work.
As a project manager on jobs,I decided that the best time to come into a project is in the middle.The first guy has to deal with getting everything scheduled and planned,parts,coordinating contractors,inspectors,etc.
The second guy gets in when most of the start up problems have been resolved and is usually easy sailing,with an occasional change order or spec change.
The last guy has to deal with the budget overruns made by the previous managers,and trying to tie up loose ends to finish on schedule.
Re: Father's Bridge
09/18/2020 1:48 PM
It's relevant to note that, in answer to the question ''How do project mistakes get made and avoided?'', your answer is ON-target.
Academic engineering-types are, essentially, taught to have the knowledge to say, in effect ''I know that the correct theory shows the answer to be (fill in the blank)''.
Whereas, the engineering technician-types tend to say things more like ''We worked on a project similar to (this) before, and found that (this one approach worked better, lasted longer, and/or cost less to install and/or maintain)''.
It's the difference between getting educated in the theory versus getting experienced in the practice.
Re: Father's Bridge
09/18/2020 1:55 PM
To the provider of the ''Off Topic'' rating of this post, I openly ask, ''Why are you not confidant enough in your rating to sign even your own (nom-de poste), as I have done with mine?...''
Re: Father's Bridge
09/18/2020 1:59 PM
Pray tell, o' divinely enlightened one, please reveal to us ignorant minions, your inspired reasoning, and explain exactly how and why you think it is off-topic, if you can?
Re: Father's Bridge
09/18/2020 3:17 PM
Is simply clicking on the ''off topic'' option the totaliity of the width, the breath, and the depth, that your (immaturity) has to contribute to this Forum? Surely, there must be something more you have to share, than just a simple click?...
Re: Father's Bridge
09/18/2020 4:22 PM
You're going a little overboard here. P911 correctly (IMHO) self identified his earlier reply as OT because it had nothing to do with bridge design or I beam selection. His and your observations on theoretical knowledge versus experiential knowledge value is important but not the topic of this thread.
Re: Father's Bridge
09/18/2020 4:08 PM
You can't tell us why, can you?...
Re: Father's Bridge
09/18/2020 4:28 PM
Before you go completely insane, I think I should tell you that when you respond to an off-topic post, your post is automatically marked off-topic by the system...If you feel that your post is somehow magically back on-topic, you can negate the off-topic designation by clicking the blue box that is checked, marked "yes, this comment is very likely to be considered off-topic" at the bottom of your post before submitting it....so that's how that works...
Re: Father's Bridge
09/18/2020 8:09 PM
I now stand apprised...
Re: Father's Bridge
09/18/2020 8:31 PM
As per Post 41, the question was, in effect, how do projects get made better during design and construction (i.e.: simpler, safer, better, etc.).
The poster showed that he addressed such issues when he changed his approach from I-beams to a rail car, which may be simpler, but may not be safer.
Effective discussion of safety is integral to any construction project, and therefore, is always on-topic, and is ignored at the (responsible ?) party's peril, as a minimum...
Re: Father's Bridge
09/16/2020 6:57 PM
Here a FYI that I’ll just put this on the table.
in wisconsin, the money gained from snowmobile licenses, some of the money for these licenses go to, subsidizing snowmobile trails (To a certain degree).
i recall, (this was about 30 + years ago) there was a huge uproar, that in a project, a subsidy was paid for a bridge for snowmobiling on an established trail. I believe it was $40,000-$80,000 I don’t recall, but it was an Exorbitant Amount, That was subsidized.
the uproar was, the cost just for a snowmobile Bridgett was similar to one of the picture SE posted.
Of course, it would need to be open to public use.
Re: Father's Bridge
09/16/2020 8:04 PM
I also have an FYI to offer. This happens all the time on Facebook. Someone will post something, and dozens of people respond without taking the time to read the previous responses.
That said, if you haven't already, go back and read #17. (It was written by the OP).
Reading every comment after #17 is optional.
Re: Father's Bridge
09/16/2020 8:51 PM
Being a community and like a lot of threads on CR4, problem taking care of, And posts wind down with just loose ends remaining that are being tied up.
for the reader, Reading is optional after post #17.
Register to Reply 49 comments
HiTekRedNek (10); MR. Guest (13); phoenix911 (8); redfred (2); roy hammy (1); Sapling (1); SolarEagle (9); traditional (1); Tyler Bingham (1); WJMFIRE (1); wmerryall (2)
