Previous in Forum: Learning About Mechatronics - Colorado Courses?   Next in Forum: Real-World Spherical Reservoirs
29 comments
Tell Me More About Miniature Motors
11/07/2007 2:35 PM
We all must know about these through the product alerts here on Globalspec or you are not subscribed to the motion and motors section. What I would like to hear is from somebody who has hands on worked with these truly miniature motors and what they are like.
It is one thing to see the figures scrolling past on your screen but what does
up to 0.014 mNm at speeds up to 15,000 rpm and
The plastic planetary gearhead is available in a 3 mm diameter with various reduction ratios allowing a continuous output torque up to 0.88 mNm and up to 1.32 mNm in intermittent operation mean to you and your application?
I would like to know what they realy feel like when it is in your hands or on your table doing whatever it is supposed to be doing?
Yes I am an engineer with some design background but we normally worked in Nm and BHp and Lbft, all big units which makes it difficult to relate to the small stuff.
I am currently working with microns and I tell you it is a revelation as what exactly goes on on that minute scale.
I would like to get to grips with what these motors do and are capable of in the real world, not some spec sheet.
http://www.faulhaber-group.com/n164058/n.html
If there is somebody out there who cares to elaborate on this, I would be much obliged.
Re: Tell Me More About Miniature Motors
11/07/2007 6:37 PM
I haven't played with anything that small, but I've used several titchy little motors from people like Portescap. Burns your fingertips when you try to stop them by grabbing the shaft. Pokey little blighters!
The motors in mobile 'phone vibrators are pretty small, and you get quite a buzz ...
11/07/2007 10:27 PM
I'm not sure this is exactly hands-on in the usual sense;
http://en.wikipedia.org/wiki/Nanomotor
Good Answers: 114
11/07/2007 11:27 PM
You're not going to break a tub w/this are you?
11/07/2007 11:37 PM
It might take some time, even with a decent blade on the end of a gear train!
Good Answers: 114
11/07/2007 11:53 PM
Not if it was a nano tub.
11/07/2007 11:58 PM
LOL. But I've only got 1, not 9. Oh no, that would be nono. I don't even have one with an aged female sitting in it.
Good Answers: 114
11/08/2007 12:05 AM
personally, I'd like a waitress to go no dressing.
11/08/2007 12:31 AM
The average UK places don't get as sophisticated as to offer dressing.
Good Answers: 109
11/08/2007 2:13 AM
Hi,
what really do you want to know, this is not clear from your statements.
I am very familiar with these motors, I am using these since now 30 years, I was near the development of the Faulhaber "Pennymotor" (see at Faulhaber website "brushless") that is 1 to 2 mm thick and 8 to 12 mm in diameter.
If you ask Faulhaber, Portescap (now part of Danaher) or Maxon may be they can send you one. If they don't I can look what I have. But first: specify your needs, what is the intended use.
Or take apart al the video players, CD players and similar device, usually there are these and the fareast makes inside.
These motors are magnificent as they have only copper and insulating laquer in the winding. This makes these motors easy to calculate and easy to use as servo motors.The winding is (most) a cylindrical shell. This winding is made with an angle to the circumferential direction of 45 to 80 degrees so that the current has a high share of axial component.The permanent magnet may be inside or outside the shell and is generating a perpendicular magnetic flux. The axial component of the current with the perpendicular magnetic flux is generating the torque.
As in any motor one limit is thermal: two thermal resistances and two thermal time constants, one winding to case, the other case to environment. Temp limits can be up to 200°C.
Another limit is maximum speed: bearings are one factor, available voltage and voltage limit in the commutating electronics or mechanical commutator is the other factor. The driving voltage ahs to overcome the induced countervoltage and the resistive losses in the coil.
The third limit is the current limit (by heat generated in the coil and limited cooling).
Torque/current is the k-factor and is the same as induced voltage/speed, speed in rad/s.
Above 500rev/sec we normally switch over to air turbines in our experimantal work with high speed airbearings that rotate up to 7000rev/sec for micro milling and grinding.
RHABE
11/08/2007 3:43 AM
Well , smallest motors i have encountered is one found in mobile phone for vibration and watches for setting analog dials , but miniturised motors only seen on televisions , internet and read in magzines , applications too may be limited to there size or we look for applications specialized for those .we need miniture sensors , ckt , to control motor
11/08/2007 3:48 AM
- sounds like the sort of thing one might find in the retractable-tray-loading-facility in a CD-rom drive.
Modelmakers use small motors. Check out Z-gauge trains for examples.
http://en.wikipedia.org/wiki/Z_scale
11/08/2007 4:02 AM
I remember reading somewhere about some guy (in the USA, I think) who won a competition to make a minute working motor. Took years to make. Apparently he brought one to the UK, and it got crushed when someone was trying to focus a microscope on it . Just had a quick look round Google, but couldn't find it - does anyone know any more about it?
11/08/2007 5:56 AM
In 1959 William MacLellan built a 1 millionth of a hp motor (1/60000 inch diameter) in response to a challenge by Richard Feynman. A book called "The Story of Measurement contains a picture of the latter looking at it thru a microscope !
11/08/2007 5:58 AM
That sounds like the one - thanks.
11/08/2007 6:01 AM
Glad to help. The book is a great read as well (Author -Andrew Robinson).
11/08/2007 5:20 AM
I know nothing about this sort of thing, but, someone borrowed my camera at work the other day and broke it (I think they dropped it). We decided to take it to bits to see if there was anything we could fix: no chance. The lens housing has several tiny motors and gears: I can post you the "remains" if you send your address to me via private message.
11/08/2007 8:38 AM
If your interested in real available miniture motors check out the following link:
http://www.newscaletech.com/
Their motors are based on ceramic technology and work well.
A pessimist sees a problem in every opportunity, an optimist sees an opportunity in every problem.
Canada - Member - New Member
Good Answers: 11
11/08/2007 10:25 AM
I was afraid by your title. You know, the type of questions ''Tell me about the quantum computer''.
I have worked with Smoovy BLDC motors in the past. My main problem with them was the plastic planetary that had to be run-in to provide the rated maximum torque.
Currently use 6mm diameter step motors.
Planning to use ultrasonic motors soon.
Some obvious and less obvious notes to ease the transition to the micron world:
  • They are somewhat robust, but care is very important.
  • Get them with a harness/flex attached. BLDC and steppers have many pins in a small space. A pain for prototyping.
  • Any contaminant, misalignment, friction, etc., while barely perceptible at best can be greater than the motor torque. (cyanoacrylate fumes, machining errors...)
  • Plan for 100% inspection.
  • Off the shelf hardware like screws, bushings are less common to difficult to find.
  • Tooling design may be inherent to the design.
  • Get a good loupe for the good eye you have left.
The source you quoted are of good Swiss quality, Good Asian sources are also possible, and some with small quantity capability.
Many modeling and R/C sites sell vibrator pager motors without the mass, gears and how to's. These can be a good cheap source for hands-on destruction.
11/08/2007 12:03 PM
I have seen the NEW SCALE motor operate and belive they live up their data sheet. My suggestion is that you call them directly and talk to them about your application. Quick articles and data sheets never give you the entire story or answers for that mater.
11/08/2007 12:40 PM
A reply to all that posted here, thank you for your input, All posts had some interesting information in them. I did not ask from a profesional angle as we use 25mm diameter 2 or 4 pole stepper motors on our equipment, I was just being nosy and will look at the equipment suggested for further real life instances for their use.
Maybe then it will also become clearer to me what they are capable of in strength terms, still not sure about that.
In reply to the nano motor post in specific, I once saw an article about nanohairs acting to electric charge in a bending kind of way. This stuff was put on a conveyor and created a beltless and roller less conveyor system that was multidirectional as well. How cool is that?
Thanks all and have a good day or what is left of it for some of you.
11/08/2007 3:00 PM
Somewhere in CR4 is some great stuff about conveyors/linear motors and stuff, but I don't recall where. I like the sound of electrostatic hair conveyors ( though I might have to be more careful than most near one).
Good Answers: 11
11/08/2007 3:12 PM
They ought to fluff your tail!
11/08/2007 3:20 PM
Maybe those hairs will move around in such away that his bath suddenly and of no doing of Kris will get broken up in no time. Unlikely seeing that he is hell bound on stalling long enough to get to the thousand posts marker. Is there a price for that, hmmm i wonder.
11/08/2007 8:35 PM
Shhhhh....
11/08/2007 3:17 PM
Why?, no mechanical rollers and such to get your tail trapped.
11/08/2007 7:41 PM
"Somewhere in CR4 is some great stuff ..." see thread http://cr4.globalspec.com/thread/13709/New-Web-Based-Encyclopedia
11/08/2007 8:34 PM
I'd heard of this 'peer-reviewed' type wiki digest. Sounds like a good idea. There is a possible plan to do similar with CR4 I heard from an authoritative source (on thread) - take the best on-topic bits and provide comprehensive abstract on all subjects. A sort of compiled sister version for those who want to get to the serious stuff. Well that's me ****** if they're only going to use on -topic ! Still, it sounds good in principle. We can all chat here as normal, generating debate/discussion and the most informative comment is taken and structured. I thus have no shame in being the grease in the discussional wheels.
11/08/2007 4:45 PM
I too have an interest in mini motors.
Keep the ideas flowing.
Good Answers: 11
11/08/2007 4:59 PM
Wat's your need?
There is realy many types and sizes.
These are happy times for small mechanics, as some can still manipulated .
Register to Reply 29 comments
case491 (3); CeraMan (2); Garthh (3); gigaconcept.com (3); JohnDG (4); Kris (9); PWSlack (1); Randall (1); RHABE (1); vikas (1)
You might be interested in: Control Grips, DC Motors, Stepper Motors
