Previous in Forum: Lightning Water Well   Next in Forum: 1P+N MCB
8 comments
Lithium Ion Battery Parameters
09/28/2020 11:41 AM
Hi All,
If would of Great help, if you can guide me in getting some of the information for Battery charging for Electrical Vehicles.
Here are some of the data
Voltage of Individual Cell3.60V
Rated capacity of one Cell : Ah3.30AH
Watt Hour Er11.88WhEr=Vc x AH
Recommended C-rate : C0.40
Charge or discharge current Ic:1.32AI = C x Er
Time of charge or discharge t (run-time) =2.50hT= 1/C
Time of charge or discharge in minutes (run-time)150.00minT*60
Number of batteries in series (Us)14.00
Number of series in parallel (Up)8.00
Voltage of the storage system (Vs)50.40VVs= Vc * Us
Peak Voltage of the Storage System (Vps)57.46VVps = 1.14*Vc*Us
Current of the storage system10.56AIs = Up * Ic
Nominal Ambient Temperature40.000%
Temperature Factor (Bt)0%
Battery Efficiency (n)98%
Depth of Discharge (DOD)80%
Capacity of the storage system (energy stored)33.67AHAH of Battery Bank=((AH)x(1+Tbot) / (n x DOD)) AmpHr
Watt Hour1697.14WhP = AH * Vs
Charger Efficiency0.90
Charger Capacity Required for C-rating1712.42W
This is a Work in Progress.
Need your guidance in telling me what factor need to be checked when we are gonna calculate Battery Charging Time for the Following.
I am looking for any technical Help in understanding more into EV Charging using LI Batteries
Charging Times and Rates
ChargerSlow ChargingNormal ChargingSemi Quick ChargingQuick Charging (DC)
Supply Voltage (Vac)240240
Input current to Rectifier44
Power Factor0.950.95
Charger Power I/P
Battery O/P Voltage4848
Charger Power O/P506.88506.88
Charger Connector Rating A616
Battery C Rating
Charging Time in hours
Re: Lithium Ion Battery Parameters
09/28/2020 12:03 PM
It is not possible to fill in the second table without contacting the manufacturer(s) of the batteries directly. It might take several calls and do let the forum know the outcome, for it might prove useful to others.
09/28/2020 1:43 PM
Battery charger....
Just make it bigger, add cooling...
09/29/2020 7:09 AM
That is a nice charger.. i like the independent info for each cell.
do you have any experience with this model?
tia
09/29/2020 9:32 AM
No I have a different one, older more expensive, but similar...
Good Answers: 225
09/28/2020 9:19 PM
Your numbers appear a little confused.
8 cells in parallel at 3.3Ah each equates to a total available Ah rating of 26.4Ah.
If you then apply a maximum DOD of 80% you have a tad over 21Ah available for use, not the 33.67Ah that you suggest.
I'm confused by the correlation between your discharge current and expected run times namely 1.32 amps (a really small RV) and 2.5 hrs. 21Ah capacity at 1.32 amp draw should provide around 16 hours runtime.
Another anomaly is that charge current of 1.32 amps. Based on your figures of 33.67 Ah capacity, your C rate of 0.4 suggests a charge current of around 13.2 amps, perhaps your have misplaced the decimal point, in which case your runtime would be closer to 1.6hrs to 80% DOD, not the 2.5hrs claimed. I would see the charge current at 0.4C to be closer to 10.5 amps. I would point out that most Li chemistries can accommodate charge rates of up to and sometimes beyond 0.8C with no ill effects
You also fail to mention whether the ambient temperature is in °C or °F which will significantly affect performance particularly when charging.
You also need to consider the actual chemistry of the cells as different charge parameters exist for various types, as do the relative energy densities, charge times, run times etc. For example typical charge parameters for LCO and LMO would be 4.2V 0.7 - 0.9C, for LFP would be 3.65V up to 1C, Getting these wrong can be quite expensive.
09/29/2020 7:27 AM
"If you then apply a maximum DOD of 80% you have a tad over 21Ah available for use, not the 33.67Ah that you suggest"
Okay - Formula Updated
"I'm confused by the correlation between your discharge current and expected run times namely 1.32 amps (a really small RV) and 2.5 hrs. 21Ah capacity at 1.32 amp draw should provide around 16 hours runtime."
21AH Capacity is of the whole Pack with 8 Series Pack cells in Parallel. SO the Run time is correct i feel
"Another anomaly is that charge current of 1.32 amps. Based on your figures of 33.67 Ah capacity, your C rate of 0.4 suggests a charge current of around 13.2 amps, perhaps your have misplaced the decimal point, in which case your runtime would be closer to 1.6hrs to 80% DOD, not the 2.5hrs claimed. I would see the charge current at 0.4C to be closer to 10.5 amps. I would point out that most Li chemistries can accommodate charge rates of up to and sometimes beyond 0.8C with no ill effects"
1.32A is the single cell current and not of the Pack
Also do we have any temperature Factor to be added when calculating. I couldn't get much info and hence with whatever info i got, i have added a factor. please let me know some of the parameters that still needs to be considered here
Please see a updated table below
09/29/2020 7:33 AM
Deleted.
09/29/2020 8:07 AM
Updated Table
Eocv / cell4.10V
Eodv / cell2.90V
Charge or discharge current Ic of one cell1.32AI = C x Er
Peak current1.50A
Time of charge or discharge in minutes (run-time)150minT*60
Number of Cells in series (Us)14
Number of series Cells in parallel (Up)8
Peak Voltage of the Storage System (Vps)57.40VVps = 1.14*Vc*Us
Current of the storage system for C rate10.56AIs = Up * Ic
Nominal Ambient Temperature450%degree C
Capacity of the storage system (energy stored)20.70AHAH of Battery Bank=((AH)x(1-Tbot) * (n x DOD)) AmpHr
Total Run time of the Battery in Hours1.96H
Total Run time of the Battery in Minutes118Min
Watt Hour1043.16WhP = AH * Vs
Peak Power of the Storage System1188.04Pp= AH* Vps
Charger Effciency95%
Charger Capacity Required for C-rating638.05W
Anonymous Poster (2); PWSlack (2); setlock77 (1); SolarEagle (2); spades (1)
