Previous in Forum: Gas Turbine Tips   Next in Forum: DIN Standards (German - Deutsches Institut für Normung )
Circulating Pump
11/09/2007 6:06 AM
hi guys! im working in a hotel. and it does hv 52 rooms with a centralized hot water system. my problem is the hot water takes alot of minutes b4 it goes to the guest rooms. our hot water source is solar and im planning to install a circulating pump but my problem is i dnt knw how to do it. can u help me what r the parameters to be consider? sad to say, its my first job and i dnt hv any experiences regarding this matter. can u help me? what are the things that comprises these system? thanx.
kaising
Re: circulating pump
11/09/2007 7:28 AM
  • Has the system been properly maintained?
  • What does the system designer and supplier have to say about the tardy delivery of hot water?
11/09/2007 7:49 AM
I would guess that the best person able to answer your question is the chap who designed and installed your system.
The information you have given is insufficient for a meaningful answer.
John.
Good Answers: 66
Re: Circulating Pump
11/09/2007 11:05 AM
It can be done and makes a world of difference (I have one in my home). The problem is that you need a full loop with a return line from your furthest point. That means you need an extra pipe in the walls to carry the water back to the tank. If installing the return line is feasible, great. If not, you could look into in-room tank-less heaters (probably electric for your application) that could supply heat until the water arrived from the tank. Does that help?
Aequam memento rebus in arduis servare mentem.
11/09/2007 10:59 PM
And to add to CSM's reply, a small bronze body circulator returning hot water from the farthest point from the water heater will keep it close by for everyone.
You can probably fish PEX pipe through the building the cheapest and easiest. This line should be insulated so as not to waste energy. It takes very little flow to make this work effectively.
Unless you're the lead dog on the sled, the view is always the same....
11/17/2007 4:25 AM
thanx for the info. that does helped me...
kaising
Good Answers: 19
11/10/2007 11:43 AM
Draw a schematic of the current system and include any pressures at various points if you have pressure gauges installed at certain places and send it to us. Include pipe sizes if possible. Distances are important to show on the drawing.
You say "solar", so does this mean a black tank on a roof with gravity flow to the rooms (like my water heater in Somalia), or a commercial solar system with pumps? If the walls are concrete or other 'heat absorbing' material the heat is warming up the walls before it finally arrives to the guest.
As pointed out earlier a constant circulation system needs a return pipe. There will be heat loss as the circulation system 'warms' up the walls so if your solar system produces 'warm' water now it will become cooler.
11/22/2007 6:21 AM
thank you very much for the info. what will be the rating/capacity of the pump to be use? thanx again.
kaising
Register to Reply 7 comments
CSM Engineer (1); Electroman (1); kaisa (2); PetroPower (1); PWSlack (1); Sniccus (1)
You might be interested in: Hot Stamping Foils, Hot Runner Controllers
