Previous in Forum: Flight Improvement Suggestions Requested for Awesome Giant Hand Launched Glider   Next in Forum: Now That is Awesome
21 comments
Engineering Fields - Electrical Engineering - seek knowledge
Sealing Machine
10/19/2020 2:25 PM
When a sealing machine stops sealing for a 1litre keg, what could be the cause? How can it be fixed to start sealing again?
Re: Sealing Machine
10/19/2020 2:40 PM
Could be an number number of things, what have you checked so far to narrow down the large list of possible causes?
Re: Sealing Machine
10/19/2020 2:49 PM
Have checked the connecting cables to the heating element of the sealer it's intact, as I checked I do not know where seems to be making partial contact as a red led on a panel inside the machine which normally comes on when it's sealing did come on and it sealed about 3 kegs and then stop sealing
Re: Sealing Machine
10/19/2020 2:47 PM
Some characters are just really good at breaking the seal of a keg.
From the Wikipedia page.
Re: Sealing Machine
10/19/2020 3:27 PM
Is it like this?
That seals with plastic by induction heating?
If so, your start button on the top may be going bad...
Re: Sealing Machine
10/20/2020 10:58 PM
Or is it more like this?
Re: Sealing Machine
10/19/2020 3:40 PM
A little more info...
if it’s a thermal heat seal that melts plastic as a seal... could be your heater platen are failing.
test them
Re: Sealing Machine
10/19/2020 4:56 PM
The <...cause...> is that it hasn't been maintained or repaired properly.
The remedy is in the Operation and Maintenance Manual for the equipment, either in the text or among the contact phone numbers listed therein for the manufacturer, and applying (an) appropriately-skilled Technician(s) to the equipment.
Re: Sealing Machine
10/20/2020 10:25 AM
Is it a vacuum sealer? If so, maybe the motor crapped out, or maybe there's a leak in the hose.
Re: Sealing Machine
10/20/2020 10:37 AM
One might envisage another game of "20 Questions" approaching...
Re: Sealing Machine
10/20/2020 11:01 AM
Ew Ew Ew, I have a question. Is it purple?
Re: Sealing Machine
10/20/2020 3:48 PM
No. Next question?
Re: Sealing Machine
10/20/2020 5:57 PM
Does it have legs?
Re: Sealing Machine
10/21/2020 2:56 AM
No. That's three. Next question?
Re: Sealing Machine
10/21/2020 9:34 AM
Re: Sealing Machine
10/20/2020 11:06 AM
Again, Can you please give more information...
now you say a 1 liter keg... Please elaborate with the machine, what you are sealing and what are you trying to accomplish.
Re: Sealing Machine
10/21/2020 4:20 AM
It seals by induction.two flexible wires covered with white insulation from a small 30tcs transformer runs to set of small iron, winded round it, produces heat from the other side of the sealer
Re: Sealing Machine
10/21/2020 2:55 AM
Any invitation to call the manufacturer from here will be declined.
Re: Sealing Machine
10/21/2020 8:56 AM
One liter is just a little more than two pints. At best that's a tiny growler, not a keg of beer. A torpedo keg is 1/6 of a barrel so it holds 19.5 liters of beer.
Re: Sealing Machine
10/21/2020 2:49 PM
Re: Sealing Machine
10/21/2020 4:29 PM
Okay, what size is that little one? I read the article and I did not see any volumes for these one way kegs identified.
Re: Sealing Machine
10/21/2020 7:56 PM
KeyKegs come in three sizes (10-, 20- and 30-litres). I'm not saying this is what the OP is talking about, but it is possible that he could have some smaller... more probably the use of the term 'keg' has a different meaning for the OP in colloquial use...Maybe he could take a picture of the device and post it...(this is clearly too much to hope for)
Register to Reply 21 comments
Brave Sir Robin (1); dgoldwaters (2); jack of all trades (1); phoenix911 (3); PWSlack (5); redfred (4); SolarEagle (4); StandardsGuy (1)
