Previous in Forum: Overcurrent Tripping of VFD   Next in Forum: Electrical Design Residential Building-Canada
13 comments
Use of Cycloconverter for Resistive Load
10/25/2020 12:48 PM
I WANT TO BUILD A 3 PHASE AND SINGLE PHASE RESISTIVE HEATER USING A CYCLOCONVERTER. FOR VARYING THE LOAD, I WANT TO USE CYCLOCONVERTR. OR PHYSICAL SWITCH TO VARY THE LOAD. MY PREFERENCE IS TO USE CYCLOCONVERTER OR OTHER CONTROL POWER CIRCUIT TO VARY THE LOAD BY USING THE CONTROL FIRING ANGLE. WHAT KIND OF SIMULATOR PACKAGE AND ELECTRONIC COMPONENTS/PARTS TO USE?
Re: USE OF CYCLOCONVERTER FOR RESISTIVE LOAD
10/25/2020 3:06 PM
Good Answers: 804
10/25/2020 4:43 PM
Why go to all the extra trouble to use a cycloconverter? For resistive heating you can just use voltage control much much simpler.
10/25/2020 7:28 PM
could you recommend on what type of voltage control and range?
Thanks
10/25/2020 8:00 PM
Research solid-state heater controllers; there are many manufacturers. As for range, no one can say until you tell us how many kW and how many phases.
10/25/2020 9:15 PM
10/25/2020 5:32 PM
As written, this does not make sense to me. A cycloconverter steps down the frequency of a higher frequency source to be applied to a load. It does not change the load itself. It also does not change the peak voltage applied to the load. The load you specify, a resistive heater, has no frequency dependent factor so changing the frequency will have little to no effect.
Good Answers: 128
10/25/2020 11:50 PM
AP,
You mention wanting to vary the load "by using the control firing angle", but then are talking about a "cycloconverter", which is a wrong name for the control you describe. I suspect you are talking about a single-phase or three-phase silicon controlled rectifier (SCR) or similar device which does not change the frequency but does change the firing angle of when during the sine wave the output is turned on. The various suggestions others have given appear to be what you were wanting.
--JMM
10/26/2020 4:12 AM
Please stop SHOUTING. Others here are trying to get some sleep.
Many heat load control applications use a simple thermostat. Why not here?
10/26/2020 7:27 AM
Re: Use of Cycloconverter for Resistive Load
10/26/2020 11:28 AM
This is interesting topic, I am looking for similar application for a load bank, but I am using Thyristors (SCR) by controlling the voltage to get a different output power to the load bank. this will be on 120VAC input and varying the voltage with 25%, 50%, 75%, and 100%. this will be done by getting a fixed 3 ohm to get 5000W power and change the firing angle of the voltage to get a lower wattage.
does this make sense? any recommendation?
10/26/2020 12:58 PM
hmmm! let me try to figure out this
P=V^2/R = ie R = V^2/P = 120^2/5000 = 2.88 ohm ie ~ 3 ohm. okay that is the maximum power. and what is the minimum power? 500W?
for min. P = 500W, what is the resistance required, under full V
ie 120^2/500 = 28.8 ohm ie ~30 ohm okay
then figure out the rest
10/26/2020 2:36 PM
It sounds like another one of those exercises in pointlessness that an over-enthusiastic recent graduate might dream up - anonymously, of course.
<unsubscribes>
10/26/2020 2:54 PM
Agreed. Here is a generic synopsis:
Can somebody change <engineered system> to perform <other task> even though it is not designed to do this? Probably somebody can but since the OP has to ask I doubt they will succeed.
Good Luck
Have a nice day
Stay Safe
Anonymous Poster (3); jmueller (1); JRaef (1); PWSlack (2); redfred (2); SolarEagle (3); Tornado (1)
