Previous in Forum: Increasing Horse Power and Efficiency in ICE   Next in Forum: Help Me Identify IC
15 comments
Valves Testing; Gate Valve/Ball Valve
01/27/2021 1:03 AM
Good day,
There was discussion with my team in regards to the attending the hydro/ pneumatic testing. the witness for these tastings, is it under maintenance team without involvement of the inspection team?
is there any reference documents can refer to clarify these responsibilities.
Re: Valves testing; gate valve / ball valve
01/27/2021 2:20 AM
The purpose of a <...test...> is to give a high level of confidence that the thing being <...tested...> will operate satisfactorily at conditions less stressful than those applied on the <...test...>. For this to be sensible, the conditions need to be established before the <...test...> takes place.
<...is there any reference documents can refer to clarify these responsibilities...>
What is not sensible is the possibility of there being no previous <...test...> procedures that can be deployed on this new batch of <...gate valve / ball valve[s]...>. If this is the case then the <...test...> protocol needs to be written from scratch. This is something proprietary to the facility/Client in question, and not something this forum can carry out on any poster's behalf.
Otherwise it isn't a <...test...>. It's merely a "jolly" for those going on the visit.
01/27/2021 4:20 AM
thank you for ur reply..
my query was regards who is the responsible for witness and certify these valves. the performer is maintenance team, then the performer can be the certifier at the same time. or should involve another stakeholder?
the reference documents such as API standards and codes. API 598 dose not specify the RACI. so any other document can I refer..
Regards,
01/27/2021 4:42 AM
This is a matter of procedure at the facility or at the organisation requiring the <...test...> to be carried out; it isn't something the forum can supply.
Start by writing the test protocol.
01/27/2021 2:21 AM
I would say if these are existing valves that require periodic testing as a maintenance procedure, then I would say it falls under maintenance....
Inspection would be an initial assessment that examined and evaluated each piece of equipment and establishes a maintenance schedule for each piece, then reoccurs yearly( or periodically) and reevaluates conditions and possibly revises maintenance and or replacement recommendations...the inspection procedure also would deal with codes and regulations that must be followed, and inventory repair parts kept on site, so a great deal of expertise is required....
Engineering personnel generally make tweaks and changes to the process over time and inform the Inspection team in case they decide to make changes to the maintenance schedule...
This is my experience, your preferences might differ...
https://www.reliableplant.com/Read/23194/total-maintenance-inspection-strategy
01/27/2021 3:55 AM
Um, <...witness testing...> implies new equipment. Just sayin'.
01/27/2021 4:25 AM
for both new installed valves and valve with PM job.
01/27/2021 4:44 AM
Start by writing the test protocol for each case.
01/27/2021 4:22 AM
ok. what about issuing the certificate? maintenance can issue it? is performer can be the certifier?
01/27/2021 4:42 AM
The user of the <...certificate...> will be the one defining what the test protocol will contain. After all, it is a record that testing has taken place.
01/27/2021 6:54 AM
...and of the satisfactory nature or otherwise of the <...test...> criteria on that particular date.
01/27/2021 7:39 AM
ok. noted.
another question.. is must any hydrotest or pneumatic test in oil and gas plant to be done in attendance of the inspection engineer, like the pressure vessel hydrotest or piping and PSVs. in case yes. what about the valves?
because there is argument, that the API does not mentioned these under inspector scope. i have doubt about it, as i could not find any clue for that.
Regards
01/27/2021 8:37 AM
<...is must any hydrotest or pneumatic test in oil and gas plant to be done in attendance of the inspection engineer...>
It depends upon the requirements imposed by the company supplying both burst/collapse indemnity and business loss insurance cover for the facility. If (one of) that company's personnel witnessed the test then that(those) individual(')s(') name(s) and signatures(s) will appear on the test certificate for the equipment that was witness-tested.
01/27/2021 10:33 AM
You can't have somebody judging their own work, you need a third party who is expert in the field...Generally the maintenance is performed by the crew, mechanics 1st grade, mechanics 2nd grade, and trainee or helpers...the supervisor of the crew assigns the work and evaluates the performance, orders parts, assigns crews to jobs, basically the boss or head of maintenance....Certification is generally done by a third party, arm's length, autonomous, expert in the field, who evaluates the performance of the maintenance department overall...then makes report on conditions and any recommendations....
01/27/2021 11:14 AM
...which is a facility-specific or organisation-specific procedure. Exactly.
GA
Re: Valves Testing; Gate Valve/Ball Valve
01/28/2021 10:24 AM
here in Austria the pressure test (hydraulic) togehter with a thighteness test (pneumatic) has to be witnessed by TUEV, Landesregierung or any other authority. This is to DIN 3C- .There has to be done a first test at the manufacturer acc to DIN standard 3A.
Normally the site test will be executed togehter with the line testing and with all vessels etc. Note that this site test must not be done against any closed shut off valve. The line or system itself has to be closed with blindflanges etc.
Register to Reply 15 comments
Conan21 (4); josef wagner (1); PWSlack (8); SolarEagle (2)
