Previous in Forum: HT Panel compartments numbering?   Next in Forum: printer require for on line printing on line in shop floor on en even surface of
Motor Shop
11/16/2007 2:33 PM
how do i strip litz wire to make a silver solder connection?
i tried a torch sand blast and sand paper with so so results the thing is I have 144 in each lead and i have a gazillion wires it seems
I know that there is a molting salt stripper but thats not very portable and i'm sure not going to hold it!!!!!!!!!!
Good Answers: 120
Re: Motor Shop
11/16/2007 10:48 PM
by litz wire made from wire insulated with polyurethane wire enamel. All the wire makers make it. The polyurethane is made to decompose at solder temperature and act as a flux.
here is one, all wire makers sell it
http://www2.dupont.com/Electrical_Insulation_Systems/en_DE/products/Wire%20Enamels/product%20template/Polyurethane.html
Per Ardua Ad Astra
Re: Motor Shop
11/17/2007 3:58 AM
Formic acid. Be careful!
Re: Motor Shop
11/17/2007 7:51 AM
The way we did it in the 'good old days', was to light a little meths burner dip the end into meths and then the flame and when the wire ends start to glow quench it out in the meths...
Works perfectly especially with enamelled insulation and cotton covered insulation...
Modern stuff is probably self fluxing enamel insulated so it should dissolve during soldering if the temperature is high enough.
John.
Good Answers: 247
Re: Motor Shop
11/17/2007 4:04 PM
The idea with litz wire is that you don't need to strip it -- the insulation melts and gets out of the away a soldering temps.
144 in each lead? 144 strands?
aurizon (1); Blink (1); Electroman (1); rcapper (1)
You might be interested in: Air Strippers, Solder, Sign and Plaque Making Services
