Previous in Forum: ATC Radar Systems   Next in Forum: Modem not connecting in Windows98.
Engineering Fields - Automotive Engineering - Race ya there... Engineering Fields - Mechanical Engineering - Take everything apart, and while you're in there... Engineering Fields - Manufacturing Engineering - Metal, Metal, Everywhere. United States - Member - Good ole' USA.
Microwave Reflection
11/16/2007 9:59 PM
I'm looking to calculate (and or eventually model, if possible) the reflection, refraction and diffusion patterns of microwaves in the spectrum of around 10-40 GHz. I'm trying to build a small array of flat panel uwave reflectors, and so I'll be mostly concerned with sheet steel, aluminium, plastic and fiberglass. Any formulas, tips, guidelines or rules of thumb would be appreciated.
Thanks!
I reserve the right to be wrong, or of no help what so ever - Del The Cat
Pathfinder Tags: microwave RF uwave
Re: Microwave Reflection
11/17/2007 7:47 AM
Owwww tricky...
I hope you have a large budget for the test instruments you will need, as well as the time.
John.
11/17/2007 4:50 PM
Actually I was just hoping to get some methods and equations for calculating the RCS of an object and then doing the modeling and tests on the computer. Not 100% accurate i know, but it'll get me close enough for what I need. Out of the research I've done I know I have to use some of Maxwell's equations and there are a few others that I need to throw in the mix, but to get a roundabout figure it's pretty straightforward. I just can't seem to find anywhere that has the equations and the methods for using them...
Good Answers: 120
11/18/2007 8:09 AM
Per Ardua Ad Astra
11/18/2007 8:38 AM
I found a couple useful bits on making an antenna but it wasn't really what I was after... I'm looking for equations for calculating the reflection/refraction/absorption of microwaves interacting with a downrange object given the material, size and orientation of the object. Even if it's just a simple calculation for a simple flat bit I'm sure I can throw something together in AutoCAD with Lisp and put a bunch of flat bits together and figure something out that way. I don't need to build any part of the microwave transmitter or receiver (Not yet, anyway, I figure I have a bunch of computer modeling to do before I go and build the object, and then and only then will I worry about building a test rig...)
Good Answers: 120
11/18/2007 9:00 AM
Per Ardua Ad Astra
11/18/2007 8:58 AM
Some inputs that might help ya.
Testing of the MESSENGER Phased-Array Antenna (344 KB)
http://messenger.jhuapl.edu/news_room/status_report_02_07_05_2.html http://discoverynewfrontiers.nasa.gov/news/newsletters/newsletter_archive/2005/April2005.swf http://www.unmannedspaceflight.com/index.php?showtopic=4468 http://www.mercurytoday.com/news/viewsr.html?pid=16518
Out Of The Inner Circle
Register to Reply 6 comments
aurizon (2); Electroman (1); Hap (1); Phoenyx (2)
