Previous in Forum: Young's Modulus   Next in Forum: Water loss from earth
pressure relief valve with alarm system
11/17/2007 4:49 AM
We need pressure relief valve for high viscous material (Resins). When it gets opening alarm has to come for operator action.
Good Answers: 97
Re: pressure relief valve with alarm system
11/17/2007 8:06 AM
You could use pressure sensors to even warn you before the pressure is to high. You could also use mechanically activated limit switches.
11/18/2007 8:29 PM
now that's a very easy process for you to build it your self or buy it. All that makes up that is a led circuit,buzzer,indicators depending on the projected need to monitor liquid,gas,or solid you will have to decided. A simple circuit design like that can be very cheap if this is a company needing this. However you will need to calculate your pressure so you can design for its need. If you would like help post your issues or contact information and i can help you design it. It's very simple.
Good Answers: 19
11/19/2007 8:04 AM
Hendrik said it correctly. Fit a Buzzer with a revolving light for the Operator.
Good Answers: 19
11/20/2007 9:08 AM
What is the viscosity and temperature of the product? How fast does the resin solidify? Any flammable issues with the product?
Anonymous Poster (1); ducon (1); Hendrik (1); Ried (1)
