I build refrigerators that are rated for 115 VAC and 60 Hz. I am considering building the same units, but configured for use in Europe (or elsewhere) with a rating of 220VAC and 50Hz. My question: Will I need to set up a different supply system to supply the 50Hz power? Ignore the voltage difference, for now. The bottom line is this: If I perform operational tests on an appliance (rating 50 Hz) with a 60Hz power supply, will my test results be relevant? There are several circuit boards in this device. I was hoping for some expert opinions before I perform a smoke test on a $1300 appliance.
