Previous in Forum: Ggladio: Moving Vehicle   Next in Forum: Millwright Exam
Anybody know of a suitable valve?
11/22/2007 12:34 PM
Does anybody know of a valve that can regulate gases [air] operating under the following conditions?
A one-way valve under 1-22 Bar pressure on the 'in side' and 1-100 Bar pressure on the 'out [non-return] side' operating at temperatures between 10-1500°C on the 'in side' and 10-6200° C on the 'out side'. Opening and closing up to 10,000 times per minute [167 x/sec]
The volume of gases [air] passing through the valves per operation would be in the region of 750 cubic centimetres.
I am thinking of a 'pea' type valve but could a tiny ceramics sphere withstand 10,000 operations per minute 24 hours a day? What size 'pea' would be required for the minimum disturbance of gas flow? Is there an off-the-shelf valve available? Is there an alternative?
I look forward to reading your words of wisdom soon
Regards, Jon London
Re: Anybody know of a suitable valve?
11/23/2007 2:52 AM
This sounds more like a pressure intensifier than a regulator if you want to increase the pressure from 22 bar inlet to 100 bar outlet
11/23/2007 12:09 PM
you need some thing like solide fule firing system just like misile ! / like rotary engine valve that can work with your 167/sec requirement but temp cant say will it work for 6200degc.
11/26/2007 5:50 AM
<6200° C on the 'out side'>
Is that a typo? It's well over the melting point of tungsten.
http://en.wikipedia.org/wiki/Melting_points_of_the_elements_%28data_page%29
11/26/2007 8:15 AM
No
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
Anonymous Poster (2); JasBond (1); PWSlack (1)
