Previous in Forum: Thanksgiving?   Next in Forum: atomic explosion
11 comments
Aluminum alloys
11/22/2007 3:03 PM
I have a Ductile Iron set of pincer arms that Curantly weigh over 30 lbs. but meet my usage needs. Can anyone direct me to an Aluminum Alloy that might replace the 80/20 ductile with out a complete redesign!
Pathfinder Tags: aluminum Alloys Ductile Iron
Good Answers: 230
Re: Aluminum alloys
11/22/2007 6:02 PM
You don't say what actual usage you have for these pincer arms.
Without seeing your existing arms,and knowing the usage requirements, it is not easy to assist you better.
Rather than aluminium alloys, perhaps you should be looking for titanium, which gives greater strength for around the same weight as aluminium alloy - Thus the arms could be of less mass - designed slimmer in cross-section etc.
Dependent on usage, (please advise further) the titanium could be fabricated, forged, or cast.
Titanium would be far more expensive than aluminium alloy, of course.
Re: Aluminum alloys
11/22/2007 10:19 PM
Well the problem there is Cost I am trying to keep them marketable! The producct is a beadbreaker for commercial tires, see at www.tirespyder.com!
thank you!
United States - Member - New Member Popular Science - Weaponology - New Member
Re: Aluminum alloys
11/24/2007 1:14 AM
I agree with RHABE that 7075 is most likely the best alloy. Much stronger and harder than 6061. I have used it many times for straightening fixtures for SST investment castings and mold tooling as well. However, having looked at your website, I would say that the cross section of those pincher bars looks a bit thin for aluminum. Of course it wouldn't cost much to have a couple of sets made out of 7075-T7 or T8 and try them.
Men are like steel, if they lose their temper they are worthless.
Re: Aluminum alloys
11/28/2007 2:01 AM
Thank you I will talk to my foundry, By the way, the cross section is roughly 2" x 2" in an I-Beam shape tapering down to Approx. 1.375" (including Plastci guard) x 6".
Good Answers: 230
Re: Aluminum alloys
11/23/2007 12:03 AM
I've looked at:
www.tirespyder.com
The type of usage shows that aluminium or other soft alloys would not stand up to the work required.
Because the work done by these arms is heavy work, often by persons who are relatively unskilled, the ductile iron is a better choice for the arms material.
Apart from the lower cost of the ductile iron, that material stands up to the required heavy work far better than a lighter softer alloy.
Re: Aluminum alloys
11/23/2007 12:16 AM
Yes but the weight issue is still prevailent to the handling of the BeadBreaker shaving 20 or so lbs off the unit is highly desirable.
Good Answers: 230
Re: Aluminum alloys
11/23/2007 12:30 AM
I can see where you are coming from.
Ductile Iron = cheap, will stand up to the arduous nature of the work, but is heavy.
Aluminium alloy = More expensive, physically larger than the iron one, to obtain the same strength, is too soft to handle the arduous work over a long period.
Titanium = Very expensive, smaller in size than aluminium alloy, but larger than iron, will wear faster than iron, but wear far less than aluminium alloy.
If cost was no problem, make the arms from titanium, with chrome/vanadium end attachment jaws, or hard chrome plate the titanium jaw ends, so you get the low wear at the jaws, with high strength and lightness of the titanium arms.
Re: Aluminum alloys
11/23/2007 12:51 AM
Some truck parts have been sucessfully replaced using cast 6061 and heat treated to T6. you do not specify a duty so it hard to give a difinitive answer
good luck
Phil
Re: Aluminum alloys
11/23/2007 1:13 AM
Current arm strength has a failure point of 14,000lbs on short side of fulcrum and 7,000 lbs on long side of fulcrum in contact with tire. But this is largely excess strength as the ram has a max power curve of 10,000lbs with just 5,000lbs at the tire as the fulcrum has a roughly 2 to 1 energy loss. Product testing over 5,000 or so tires has shown no tire bead has required more than 3,800lbs of force at the ram to break the bead.
P.S what about almag alloys, how do they stack up.
Good Answers: 109
Re: Aluminum alloys
11/23/2007 2:24 AM
Hi,
if no corrosive environment there you should try Al 7075.
It is used for high strength applications. (airplane landing structures)
I would not recommend temper T6 but prefer T7 or T73 or T76 as these conditions are much more stable.
With this material you can do a 1 to 1 replacement of your parts but attach some tips as recommended above.
If you need the same elastic properties you will have to change the shape as elastic modulus of Al-alloys is a factor of 3 lower than of Fe-alloys.
RHABE
Re: Aluminum alloys
11/23/2007 6:21 AM
Suggest you consider A201 cast Aluminum - available from most foundries as sand, plaster or investment casting. Very good castability, with the yield/tensile properties of mild steel. The existing part in ductile iron was no doubt cast, therefore pattern equipment probably exists - but the difference in shrinkage would provide somewhat different dimensions. Examine the source of the existing part, then discuss with the foundry.
Register to Reply 11 comments
Anonymous Poster (1); garyceng (1); philiplyon (1); RHABE (1); Sparkstation (3); Spyderman (4)
