hey, ive created an LED bar graph using an LM3914 driver, it measures from 0 - 2.4V and when i use a potentiometer to simulate this it works fine. the problem is i need to run it off an output that would normally control an hydraulic solenoid, we can control it to put out 200mA - 700mA, when i run that current through a 3.3 ohm resistor and measure the voltage dropped it is within the range i want, but upon hooking the signal wires across the resistor the system wont work, can anyone give me some idea's as why it wouldn't work when it runs fine off the potentiometer ????
