Previous in Forum: Two Fire Pump In Series   Next in Forum: API 5L Line Pipe
Power Required To Drive
11/27/2007 4:50 AM
what should be the power of the motor required to drive a pump of capacity 7000m3/hr and the pressure difference is 5kg/cm2? The efficiency of the pump is 90%.
Re: power required to drive
11/27/2007 5:09 AM
Convert the pressure to N/m2. Multiply by the flowrate. Divide by the efficiency. Divide by 3600sec/hr. Answer is in Watts. Done.
Good Answers: 137
11/27/2007 6:36 AM
Hello PW - only thing I'd add to that is I'm sceptical about the 90 % pump efficiency. It's a big pump (~1200 kW) but even so 90 % is optimistic. Axial flow (propellor-type) pumps have good efficiency but I suspect 5 kg/cm2 is above their pressure range.
Cheers.....Codey
11/27/2007 5:23 AM
Re: Power Required To Drive
11/28/2007 8:28 PM
Hey, there is only a period. Ooooh....I get it.
Codemaster (1); PWSlack (2); TexasCharley (1)
