Previous in Forum: Hyperloop Horror Movie   Next in Forum: How UV Light Affects Your Skin?
15 comments
Polish Brass
03/16/2021 11:08 PM
I have some square brass tubing,
It is 3/8" square, The surface quality is as seen in the image. What would be the best/easiest way to polish it up to be as close to a mirror like surface as possible?
Thanks
Joe
Re: Polish Brass
03/16/2021 11:14 PM
After polishing the surface you might want to preserve it from tarnishing with a clear coat...
Re: Polish Brass
03/18/2021 4:16 AM
Unfortunately in my experience the clear coating is not really airtight and the brass underneath will tarnish which leaves you with a worse end result requiring the stripping of the clear coat before you can polish it again.
Remember the Japanese motorbikes where the lower Quality Aluminium casting when polished was sprayed with clear coat, great on the showroom floor but out in the real weather disaster.
Hare today, goon tomorrow!
Re: Polish Brass
05/05/2021 2:59 PM
That's probably because the surface was not properly prepped, or the clear coat was scratched or something....If done properly, the clear coat is moisture and air tight...
https://www.practicalmachinist.com/vb/general/clear-coat-brass-237196/
Re: Polish Brass
03/16/2021 11:45 PM
Brasso.
The ammonia smell takes you right back into the barracks late at night getting those belt buckles oh so shiny. And the copper pipes in the latrine.
Re: Polish Brass
03/17/2021 9:26 AM
I used to play the Sousaphone in the band.
I used a lot of that stuff!
Re: Polish Brass
03/17/2021 3:49 AM
, then
Re: Polish Brass
03/17/2021 9:45 AM
What is the thing on the left?
I tried just the Brasso, and I guess I have to do all the super fine sanding first. it got to the bright brass color but still a satiny finish no mirrorlike.
Re: Polish Brass
03/17/2021 11:15 AM
The Brasso will remove the oxide but the micro-pits may require some elbow grease. Maybe a buffing wheel on an electric drill might polish it off...
Re: Polish Brass
03/17/2021 11:29 AM
Glassfibre brush. Used by traditional draughtspeople and model-makers, among others.
Good Answers: 48
Re: Polish Brass
05/05/2021 4:47 AM
You could try T-Cut first, then Brasso. It works for me.
Re: Polish Brass
05/05/2021 9:03 AM
Never heard of T Cut, but did do the multiple grades of sanding then a polishing wheel, came out not too bad,
Good Answers: 151
Re: Polish Brass
03/17/2021 2:34 PM
Elbow grease used with progressively finer abrasive paper up to 600 grit, followed with rouge with a cloth buffing wheel.
Re: Polish Brass
03/18/2021 4:23 AM
I always use Brasso to polish brass and use a lambswool buff on a sander with speed control to buff the brass back to mirror finish and finish off with a clean buff. Depending on the size of the tube and the surface finish it may need to be sanded with wet and dry paper starting with 600 grit and going to 1000, 2000 and 5000. You can use jewelers rouge and a power buff if you really want to get a superb finish after the wet and dry and have the hours to spend.
Re: Polish Brass
03/18/2021 5:40 AM
Brass is soft and will sand/buff easily. I agree with the Brasso. However, the brass will soon tarnish and any clear coat will detract from the mirror finish. Perhaps this is why the old-time engineers who took care of equipment always carried a polishing rag with them and used it on a routine basis.
Don't follow in the footsteps of someone who you wish to emulate. Instead, seek what they sought.
Re: Polish Brass
03/18/2021 11:38 AM
Back in my navy days, we used the heck out of this...
Register to Reply 15 comments
Brave Sir Robin (1); EBrown (1); gringogreg (1); Holzfeller (1); jhowdy (1); NSS (2); PWSlack (2); Rixter (2); SolarEagle (2); Stef (2)
