Previous in Forum: Software Review   Next in Forum: autonomous ground vehicle methods
12 comments
Water Pump
11/27/2007 10:05 AM
I'm trying to find a 12 volt pump to put out 15-20 G.P.M @ 15-60 P.S.I. or is there another way to run water pump with these spec's other than hydraulically.
Re: Water Pump
11/27/2007 10:29 AM
So the 12V pump motor would draw somewhere north of 40A. Some pump!
Re: Water Pump
11/27/2007 11:49 AM
And it's got to run of solar power!
Re: Water Pump
11/27/2007 8:08 PM
www.sunpumps.com is one, if you need more e-mail me.
Good luck,
James
" adapt, improvise, overcome "
Re: Water Pump
11/28/2007 2:13 PM
With a typical peak efficiency of about 70%, he would need at least 64 amps on the to do 20 gpm at 60 psi.
Re: Water Pump
11/28/2007 2:52 AM
There are someone.
Please see this link and find someone as same:
http://www.systemcooling.com/swiftech_mcp655-01.html
Goodluck.
Nature is unlimited, human's knowledge is limited
Re: Water Pump
11/28/2007 8:30 AM
Thanks for the info. This pump is perfect except for the G.P.M. I need a pump with a larger volume.
Have a great day!
Re: Water Pump
11/28/2007 10:58 AM
Put a few of them in parallel, make sure your inlet and outlet pipe doesn't restrict the flow.
Pumps in parallel increase the volume.
Pumps in series increase the head.
Re: Water Pump
11/28/2007 10:05 PM
What kind of pump is it?
And try it:http://www.wholesalepumps.com/index.cfm?DID=83
Or if possible use 100VAC pump and contact relay switch with 12VDC source.
Goodluck.
Re: Water Pump
11/28/2007 6:32 AM
Engine driven pumps either diesel or petrol would do it quite easily and cheaply!!!
Re: Water Pump
11/28/2007 1:40 PM
Try Grainger (offices in all major cities) for numerous pumps that would meet this need. Great people to do business with and their prices are very reasonable.
Steam Engine Mike
Re: Water Pump
11/28/2007 2:16 PM
Mike, I always thought they were high as ----!
James
Re: Water Pump
12/05/2007 7:41 AM
Hello All
I think you Should search For A Grundfos pump.These pumps can be perfect for water application.
Visit this website: www.Grundfos.com
Hope it will work with u.
Thanx
Eng Dania
Register to Reply 12 comments
Andy Germany (1); Anonymous Poster (3); hastingselectric (2); Mr. Truman Brain (1); nam70 (2); PWSlack (1); Research Guy (1); Steam Engine Mike (1)
