Previous in Forum: Lab Setup On Robotics   Next in Forum: pumping
9 comments
Volume Of Air Flow And The Pressure Developed
11/29/2007 3:58 AM
Speed of a fan is 60m/s. what is the volume of air flow and the pressure developed?
Re: volume of air flow and the pressure developed
11/29/2007 5:09 AM
Depends upon a number of factors relating to the fan size, shape, impeller angle of attack, etc., etc.
11/29/2007 7:04 AM
"Speed of a fan is 60m/s" - do you mean the airflow, blade tip speed, or what? Or is the fan moving?
12/08/2007 2:47 AM
limit switch question,,,,,i have a wood burning furnace,never understood those limit switches,3-dials on a rotary disk,,, how do i control when fan cycles on and off?
Location: Somewhere in the hills of Pennsylvania, I think.
Re: Volume Of Air Flow And The Pressure Developed
11/30/2007 12:32 AM
Another homework assignment???
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
11/30/2007 4:54 AM
I think there is some misinformation.
Fan speed, as any other turning machines, use to be given in RPM. You give us a linear velocity that is not possible to know to what thing correspond.
As said before by other colleagues, you need give more information.
What about measuring the air velocity? It's very simple and normal flow equations will give you the information requested.
Engineering Fields - Piping Design Engineering - New Member
11/30/2007 10:50 AM
I wont even answer this ons........
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
11/30/2007 7:15 PM
But you did..........and quite correctly!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Good Answers: 18
11/30/2007 6:15 PM
There is way too little information given to even attempt a reply. Please give us more information so that we may be of help. What do you really want to know?
11/30/2007 7:13 PM
Ok, so we will take it that it is the AIR speed that is 60m/s. To know the VOLUME of air moved, we need to know the diameter of the 'conductor' i.e. pipe! If you provide this information, we can at least answer a part of the question.
To answer 'the pressure developed' will require information on the down stream 'SYSTEM' and the type of fan etc.
agua_doc (1); Anonymous Poster (1); Beej50 (2); Ferrari_Guy (1); FKIA (1); JohnDG (1); Kwetz (1); PWSlack (1)
