I'm a young engineer in the MEP business without much guidance. Can some of you more experienced and much wiser engineers give me some advice? I typically have nasty renovation projects that require new load to be added to existing panelboards. Sometimes these projects have existing drawings that are somewhat correct, sometimes they do not. Without hiring an electrical contractor to physically go around and circuit trace each branch-circuit on a panelboard or hook up a data logger, is there a way to determine how much existing load is on a panel? If it's the only panelboard in the system for very small jobs it's easy because the information can be retrieved from the serving utility. But what about if the board is one of many and is downstream from multiple boards?
Thank you in advance. Any advice is more than welcome.
