Previous in Forum: Polorized capacitor re magnet charger   Next in Forum: Building Management System
In formation on process
11/29/2007 8:25 PM
1.Inverter matter,why does the inverter easy to malfunction after replace to another?
Model; yaskawa Verispeed616G5.
2.Instalation of a small and compact model wire cleaning equipment at line (for copper wire cleaning) is it possible to install ultasonic type for this purpose same time?
Thank You
Patrick
Justez
Good Answers: 230
Re: In formation on process
11/30/2007 12:52 AM
Hello Patrick,
Your above question as asked, is not saying clearly what you are wanting to know.
If you re-format your questions, then you may be helped.....
11/30/2007 6:09 AM
< 1.Inverter matter,why does the inverter easy to malfunction after replace to another? Model; yaskawa Verispeed616G5. >
If the question relates to a replacement inverter that malfunctions after substitution, then it would indicate either a continuing fault in the downstream circuit or an error in the parameter settings in the replacement inverter.
If the question relates to the replacement of a malfunctioning inverter rather than its repair on-line, then it is simply because its repair off-line is more cost-effective, as the replacement inverter is getting the process back up-and-running. It's called, "component-exchange maintenance".
Re: Information on process
10/18/2008 10:51 AM
Mr.G,
Thanks for the reply but i dont work at the same manu plant anymore but just incase will put in some questions for some reply in the futhure.
Thank You
Paddy
Justez
11/30/2007 6:23 AM
I can give you my reply only for question # 1 only as follows;
Whenever you replaced an inverter you have to download the a parameter set in it(for this you must have backup of original one), because inverter is programmed according to application. All new inverter comes with factory settings of parameters.
If you already have done this then please write the actual problem you are experiencing.
12/01/2007 2:14 AM
Hi Patric,
Your question is not clearly. What malfunctions were? And How long and what did malfunction appear after installing by new one?
The ultrasonic cleaning device only effects in liquid enviroment, then use drier,....
And can you tell us more clearly again what kind of dust or.... you need to remove from your copper wire?????
Have nice weekend with some botles of beer.
Nature is unlimited, human's knowledge is limited
12/01/2007 10:08 PM
Hello Patrick. About Q1:
I think you have problem in explaining your problem.
Say in simple words step by step to clear your question.
All such Equipment by manufacturers has clear Instructions to configure for a particular job. If its documents lack info about your particular job, consult the supplier or manufacture for advice & help.
I have seen Inverters in cotton Industry [largest users], even the older models are user-friendly, what to say about the latest models. With such inverters a "Control" comes for configuration on any of tht model. Itconnects to inverter & do the job.
The people note down all the steps needed to configure.
Register to Reply 6 comments
Haajee (1); nam70 (1); Patrick (1); PWSlack (1); Sparkstation (1); Syed Ziauddin (1)
