Previous in Forum: Solar Power Battery   Next in Forum: Acoustic Rig For Detecting Mechanical Errors
Rust Protection
11/30/2007 4:13 AM
Can yu give us compatability comparison chart for VCI Paper and Rust preventive oil in order to protect Bearing components from Rust
Re: Rust protection
11/30/2007 4:58 AM
Local climatic conditions wil determine local performance, and therefore it is most unlikely that a globally-coordinated chart is either available, or of any value over and above local experience.
Re: Rust protection
12/01/2007 4:55 PM
Indeed, there is a world of difference in trying to protect a surface from rusting depending on conditions. Personally, I always felt safer using RP oil, because depending on the ambient conditions the materials are subjected to during transit, it is readily possible to transfer moisture through the VCI paper and condense moisture on the part. I would also consider another option: use of thin metallic foils for packaging, such foils are much more effective against moisture ingress through the paper.
Good Answers: 18
Re: Rust protection
12/01/2007 4:59 PM
Sorry, forgot to login for former post.
Register to Reply 3 comments
agua_doc (1); Anonymous Poster (1); PWSlack (1)
