Previous in Forum: Design Considerations of a Dual Double-Cantilever Spring System   Next in Forum: Slot on Top of Nut
Calculating the Differential Head of a Pump
12/03/2007 5:08 AM
how to calculate the differential head of a pump?
Re: differential head
12/03/2007 6:22 AM
Read the manufacturer's spe'c or measure it (simple pressure gauge on the output).
I don't really get 'calculate it'... calculate it from what?
12/03/2007 6:24 AM
PS.. If it really is differential, move pressure gauge to the input.... subtract one from t'other....
Re: Calculating the Differential Head of a Pump
12/03/2007 11:47 PM
TOTAL DIFFERENTIAL HEAD (THD)=System Head = total discharge head - total suction head, i.e.
H = hd - hs
hd = hsd + hpd + hfd hs = hss + hps = hfs where: hd = total discharge head hs = total suction head hsd = discharge static head hss = suction static head hpd = discharge surface pressure hps = suction surface pressure hfd = discharge friction head hfs = suction friction head
manirul
12/04/2007 12:27 PM
Do you want to MEASURE the Diff. Pressure developing?
Then you take Gauge Pressure at Outlet P2
And maybe < Negative>= Pressure below atmospheic> at Suction. P1
p2-p1 Is Pump's Diff . Pressure at that place.
07/11/2008 4:49 AM
Subtract outlet pressure and inlet measured pressures. Convert then the differential pressure into head
e.g.
Differential Head (m) =(p(bar)*10.1)/Sp. gravity
you will get differential head across the pump!
07/01/2024 8:02 AM
One uses arithmetic: subtract the inlet pressure from the outlet pressure.
Simplesξ.
Anonymous Poster (1); manirul (1); MUKULMAHANT (1); PWSlack (1); user-deleted-1105 (2)
