Previous in Forum: Biodegradable Cationic Softener Dryer Sheets   Next in Forum: Improving the Tint of Carbon Black
8 comments
Calculating Process Line Size
12/05/2007 2:01 AM
what are the basic stretigy to calculate process line size
User-tagged by 1 user
Good Answers: 18
Re: Calculating Process Line Size
12/06/2007 9:25 AM
Please provide more information. To what type of process line are you referring? It makes a substantial difference.
12/17/2007 12:12 AM
line size has to design at bypass of existing line, which has flow rate 34040 Nm3/hr, at 46 deg C containing gas 75 mole% of CO2. What flow rate should be taken for bypass line? and how to calculate the optimum line size?
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
12/17/2007 7:00 AM
What is so important about the bypass line? If it's a bypass; just make everything equal!
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
12/20/2007 3:32 PM
You need pressure drop allowable. If you have 150 bar available, it might be a 2" line. if only .15 bar, you'll need a 20" line.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
12/06/2007 1:14 PM
You'll never get an answer with a question like that. You need to provide some specifics.
Money doesn't talk, it screams in your face.
12/17/2007 7:54 AM
How much i be the specific more than this?
12/10/2007 5:47 AM
3m/sec can be considered the upper economic limit for liquid velocity in pipes. Take it from there?
12/16/2007 11:37 AM
A strategy is a plan; it is documented ideas of a process or project undertaken that results in a viable result or product. You start by visualizing what it is you want.
Ask yourself:
Who? What? When? Where? Why?
Register to Reply 8 comments
agua_doc (1); betomachine (1); meshri (2); PWSlack (1); ronald (2); vicini (1)
