Previous in Forum: 12V DC Motor End Cap and Brushes   Next in Forum: Control Valve Sizing
Horizontal Inlet and Outlet Control Valve
03/29/2021 1:36 AM
We are in need of angle control valve with horizontal inlet and outlet at 90 degree to each other and valve should be in vertical position. Which of the companies manufacture such CV.
Pathfinder Tags: control valve
Re: Horizontal Inlet and Outlet Control Valve
03/29/2021 8:19 AM
You probably need to provide additional information.
Valve size, material being transferred, flow rate and pressure rating would probably help.
If it is large or has fast flow rates, then the valve would also require thrust blocks and such for stability.
03/29/2021 8:53 AM
With only the information provided,I suggest a 90degree elbow in the horizontal leg,and a 90 degree elbow in the vertical leg,with the valve mounted in the vertical leg.
This could be fabricated in-house or contracted out.
If this is not what you had in mind,provide more details on your requirements and application...blueprints,etc.
03/30/2021 4:55 AM
that depends on size and pressure rating, but i know very well some of fisher controls and danfoss.
Suiteable for natural gas as well as saturated steam.
best regards from Vienna, Austria
03/30/2021 5:12 AM
This question is best answered by talking to the local friendly Valves Distributor directly. Make some calls.
03/30/2021 7:15 AM
Houses in the UK are full of these.
04/01/2021 4:36 AM
Register to Reply 6 comments
HiTekRedNek (1); josef wagner (1); Just an Engineer (1); PWSlack (2); Randall (1)
