Previous in Forum: Horizontal Inlet and Outlet Control Valve   Next in Forum: Pressure Loss in Feed Water Heater
Control Valve Sizing
04/06/2021 1:15 AM
I want to do sizing of deaerator level control valves. Pressure on upstream of CV is 24 bar. Downstream , there is 70 m long 800 mm dia line which discharges into deaerator at 11bar. What will be Delta p for CV. What I have done is to calculate line losses and added deaerator pressure to find downstream pressure of CV. The difference of pressure between downstream and upstream will give Delta p across the CV. Am I correct. Based on this I calculate Cv.
Pathfinder Tags: Control Valve Sizing
Re: Control valve sizing
04/06/2021 1:37 AM
04/06/2021 3:38 AM
Open a dialogue with the local friendly Valves Distributor, and get that organisation to provide a quotation. That way, the liability for getting it right lays with that organisation.
04/06/2021 3:47 AM
Is this the same control valve?
How did those calls to the Valves Distributor go?
Re: Control Valve Sizing
04/06/2021 7:05 AM
The Valve Distributor will need to know the fluid and its temperature, among other things of little interest to the Mechanical Engineer.
Good Answers: 137
04/09/2021 12:33 PM
That's the right basic approach. I assume it's water as it's a deaerator. If you calculate line loss at maximum flow that will you minimum valve ΔP hence max Cv. As the valve will most likely be smaller than line size, divide by 0.8 swaging factor to get required Cv. But if it's a control valve you probably need to consider other conditions. Calculate minimum Cv from minimum flow and maximum valve ΔP, based on lower line loss, plus any higher upstream pressure or lower deaerator pressure, if that's a possibility. Use swaging factor 0.9 or 1 for safety.
That gives the range of Cv, needed to correctly size a control valve. Give that to the valve supplier, along with the water temperature, to check for cavitation, which could be a problem at this sort of ΔP.
As it's a 800mm dia line it's going to to be a big valve, I doubt there are many suppliers who can do it. Check what they offer, they're not all too competent, though at this level one hopes they are. In the past I have given all the process data to valve suppliers, with line size, saying valve size to be advised by supplier, assuming it would be 1 or 2 sizes below line size. Sometimes they would ignore the process data completely and just quote a line size valve.
04/16/2021 5:15 AM
The link below to a valve manufacturer has a calculator for your purpose.
https://go.emersonautomation.com/FSMDownload
It has specification manager software.
It should be useful even if you do not use their brand of valve.
It took less than 30 seconds to find it.(yawn)
Good luck!
04/23/2021 9:29 AM
⇒ "The Chemical Engineer" magazine, April 2021, pages 48-50.
⇒ "Rules of Thumb for Chemical Engineers" 6th Edition, by Stephen Hall, (Elsevier, 2018)
Register to Reply 7 comments
Codemaster (1); HiTekRedNek (1); PWSlack (4); SolarEagle (1)
