Previous in Forum: Timer Control for Heater   Next in Forum: Pickle Power
Applications for Power Cables vs. PVC Insulated Cables
12/05/2007 6:49 AM
Dear Sir,
In electrical installation what are the applications where we must use power cables (600/1000 v governed by BS 6004) instead of normal PVC insulated cables (300 / 500 V ) to feed, 3 phase (400 V) or 1 phase(230 V) power distribution boards?
Re: Applications for Power Cables vs. PVC Insulated Cables
12/05/2007 5:08 PM
Asitha, I don't know what BS 6004 is. Can you tell me? I would like to read this standard. But in America the insulation must be rated for the voltage it carries.
The type of insulation will vary depending on the environment it is in. We use a series of "tables" to determine what our code requires.
James
" adapt, improvise, overcome "
12/06/2007 12:59 AM
which cable you are using copper or alluminium then i can help you
12/06/2007 3:15 AM
Cu cables,
The 300/500 V cables are governed by BS 6004 or IEC 227 standards and 600/1000V cables are govened by BS 5467. Here I don't know why those standards give two voltages, such as 300/500 without giving one value. Does this mean 300 V corresponds to 1_ ph voltage & 500 corresponds to 3-ph voltage?
04/11/2008 2:15 PM
Hello
I have answered your Post/comments,
Generally best to use the Cable Maker of your particular cable, but try:
http://relemaccables.com/
If you are still needing help, reply with
Kind Regards....
Register to Reply 4 comments
Anonymous Poster (1); Asitha (1); hastingselectric (1); joginder pal singh (1)
