Previous in Forum: Measuring Gas Pipe Pressure   Next in Forum: Lux Meter For Measurement of Light
Vibration Table Sensor?
12/06/2007 9:51 PM
What sensor can I use to measure the oscillation length of a vibration table oscillating at about 5 Hz?
Good Answers: 230
Re: Vibration Table Sensor?
12/06/2007 11:19 PM
Hello Guest,
I found this for you:
Fiber-optic vibration sensor
The sensor comprises a vibrating sheet (1), mechanically connected to the body (5A) to be analyzed, and an optical triangulation recording system for recording the displacements of the movable part of the sheet, in particular the free end (1B) opposite to that which is restrained. The recording system comprises two optical fibers (7, 9) ending in microlenses (10, 12) having optical axes mutually inclined and converging in the movable part (1B) of the sheet.
http://www.freepatentsonline.com/5063781.html
Hope that assists you....
12/07/2007 7:27 AM
The standard way to measure and monitor vibrations such as this is to use an accelerometer attached to the table, with the correct conditioning amplifier you can take measurements of velocity acceleration and amplitude etc...
Much simpler than messing about with optics and multiple sensors. Simply attach the accelerometer and measure!
John.
12/07/2007 11:58 PM
Guest:
If you only want to know displacement, attach a $5 laser pointer to the shaker table and point it at a ruler mounted on the wall. Velocity and acceleration can be derived from the displacement (and frequency).
Good luck.
DickL
12/09/2007 12:29 PM
Do a search on proximity probes, probably your best bet.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
12/11/2007 3:24 AM
I agree with the accelerometer solution as the best suited.
Anyway here is my small contribution: You can attach a spring loaded rope potentiometer to the table and mount the other end to a fixed point. This will give you a voltage proportional to the displacement. If you only want to measure the displacement, a normal multimeter with peak retention function is enough. If you want more information and have a data adquisition system, then you can get not only the displacement but also the other relative parameters: velocity, acceleration and frequency.
I've made it to measure piping systems transients. Furthermore, to avoid the possible variations in the primary voltage, I measure it and the software (Labview or DasyLab from NI) divided the signal by the feeding voltage.
DickL (1); Electroman (1); Kwetz (1); Sparkstation (1); Steve S. (1)
You might be interested in: Vibration Instruments, Vibration Sensors
