Previous in Forum: Site Search function   Next in Forum: Why do we lose the editing icons and other permissions?
Wing loading calculation
07/05/2022 3:55 AM
I am building a radio controlled model of the WW2 Westland Whirlwind fighter. The wing span is 63 inches and will have 2 electric motors as power sources. I would like to calculate the wing loading but am unsure of whether I should take the total area (upper surface) or use the lower surface area which would exclude the area of the nacelles.
Your advice is appreciated.
Tony Aston
Re: Wing loading calculation
07/05/2022 5:32 AM
07/05/2022 7:50 AM
This site says to use the upper surface area.
"To calculate wing loading, divide the mass of the bird or plane by the total area of the upper surface of its wings: wing loading = body mass (kg)/wing area (m2)."
https://www.sciencelearn.org.nz/resources/301-wing-loading
07/05/2022 8:37 AM
Since you mentioned mass, with using electric batteries, be aware of the center of mass on the plane is. Placement can be critical.
07/07/2022 2:07 PM
07/08/2022 8:40 AM
Thank you all for your help and guidance. Here in the UK there is a project to make a full scale replica https://www.whirlwindfighterproject.co.uk
I will keep it simple and measure the wing area and then weigh the plane when it is ready to fly.
Thank you
Tony Aston
07/14/2022 6:02 PM
Register to Reply 6 comments
phoenix911 (1); Rixter (2); SolarEagle (2); Tony Aston (1)
