Previous in Forum: Reducing a metal plate thickness   Next in Forum: Angular acceleration of pivoting assembly
Rotational speed of an electric screw jack
08/17/2022 8:47 AM
Is the rotational speed or translational travel speed of an electric screw jack always be a constant value in both loading or unloading conditions?
Re: Rotational speed of a electric screw jack
08/17/2022 12:08 PM
08/17/2022 1:00 PM
It will be if the motor can be driven at a constant speed regardless of the torque requirement.
For instance, if a permanent magnet synchronous motor (PMSM) is driven by an inverter (motor drive) and it can be programmed to operate at a constant RPM (within the torque limitations of the motor of course), then yes, the screw jack speed will be constant.
An AC induction motor speed varies somewhat over no-load to full-load conditions.
08/17/2022 10:04 PM
A closed loop Servo.
08/17/2022 10:21 PM
For a PMSM is driven by an inverter and it can be programmed to operate at a constant RPM, is the power consumption will be affected by loading or unloading?
08/17/2022 10:35 PM
Yes.
08/19/2022 1:04 PM
Something about the Law of Conservation of Energy.
Register to Reply 6 comments
Brave Sir Robin (2); phoenix911 (1); SolarEagle (1); Tornado (1); youngken (1)
